0 Replies Latest reply on Aug 17, 2009 11:32 AM by Paul Reilly
    [svn:fx-trunk] 9349: * Added support for using getStyle() in Mxml data binding expressions.
    Paul Reilly Level 1
      Revision: 9349
      Author:   preilly@adobe.com
      Date:     2009-08-17 11:32:37 -0700 (Mon, 17 Aug 2009)
      Log Message:
      • Added support for using getStyle() in Mxml data binding expressions.
        In addition to the existing "function return watcher" data binding
        functionality, we register to listen for style related change events
        when we see a function marked with [Bindable(style="true")].
        UIComponent's and TextGraphicElement's styleChanged() will now
        dispatch events for "getStyle()" FunctionReturnWatchers to handle.
        When null or "styleName" is passed into styleChanged(), we dispatch
        an "allStylesChanged" event.
      QE notes: mxunit test to follow
      Doc notes:
      Bugs: SDK-20394
      Reviewer: Glenn, Pete F, Peter D
      Tests run: checkintests, mxunit databinding
      Is noteworthy for integration: only if you want to start using it.
      Code-level description of changes:
        modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension.java
          Modified generateWatcher() to do the AST equivalent of the
          WatcherSetupUtil.vm change.
        modules/compiler/src/java/flex2/compiler/as3/binding/FunctionReturnWatcher.java
          Removed unused isNew variable and added isStyleWatcher variable.
          Modified shouldWriteSelf() to return true if isStyleWatcher is true.
        modules/compiler/src/java/flex2/compiler/as3/binding/WatcherSetupUtil.vm
          Modified writeFunctionReturnWatcher macro to add a true arg to the
          FunctionReturnWatcher constructor call when isStyleWatcher() is
          true.
        modules/compiler/src/java/flex2/compiler/as3/binding/BindableFirstPassEvaluator.java
          Modified evaluate(Context, MetaDataNode) to skip reporting an
          error for no events when style is true.
        modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassEvaluator.java
          Replaced insideCallExpression boolean with callExpressionStack
          Stack.  The "!insideCallExpression" checks were replaced with
          callExpressionStack.isEmpty().
          Modified addBindables() to handle [Bindable(style="true")].
          Made argumentListStack and resetSet more strongly typed.
        frameworks/projects/framework/src/mx/core/UIComponent.as
          Modified styleChanged() to dispatch a "Changed" and "allStylesChanged" from the previous
          parent and add listeners to the new parent when isStyle is true.
          Modified eventHandler to notifyListeners() when isStyle is true.
        frameworks/projects/spark/src/spark/primitives/supportClasses/TextGraphicElement.as
          Similar changes to UIComponent.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-20394
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/FunctionReturnWatcher.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/TextGraphicE lement.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableFirstPassEval uator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/FunctionReturnWatcher .java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/WatcherSetupUtil.vm
