3 Replies Latest reply on Aug 17, 2009 6:06 PM by Tara Jane Feener
    Making Button links help - Extended
    SplendidAngst
      Okay, I had some great help earlier with creating a button that linked to an external page with the use of Flash Builder.
      I have no problem with that...my new issue is with 5 buttons.
      Here's the code I have to look forward to dealing with in Flash Builder -
      <s:Skin xmlns:s="library://ns.adobe.com/flex/spark" xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:d="http://ns.adobe.com/fxg/2008/dt">
          <s:transitions>
              <s:Transition fromState="down" toState="up" autoReverse="true">
                  <s:Parallel>
                      <s:Parallel target="{bitmapimage1}">
                          <s:Move autoCenterTransform="true" duration="250"/>
                      </s:Parallel>
                      <s:Parallel target="{bitmapimage2}">
                      </s:Parallel>
                  </s:Parallel>
              </s:Transition>
              <s:Transition fromState="up" toState="over" autoReverse="true">
                  <s:Parallel>
                          <s:Fade duration="250"/>
                      </s:Parallel>
                      </s:Parallel>
                  </s:Parallel>
              </s:Transition>
              <s:Transition fromState="up" toState="down" autoReverse="true">
                  <s:Parallel>
                          <s:Move autoCenterTransform="true" duration="0"/>
                      </s:Parallel>
                      </s:Parallel>
                  </s:Parallel>
              </s:Transition>
              <s:Transition fromState="over" toState="up" autoReverse="true">
                  <s:Parallel>
                      </s:Parallel>
                      </s:Parallel>
                  </s:Parallel>
              </s:Transition>
              <s:Transition fromState="over" toState="down" autoReverse="true">
                  <s:Parallel>
                      </s:Parallel>
                          <s:Fade duration="0"/>
                      </s:Parallel>
                  </s:Parallel>
              </s:Transition>
              <s:Transition fromState="down" toState="over" autoReverse="true">
                  <s:Parallel>
                      </s:Parallel>
                      </s:Parallel>
                  </s:Parallel>
              </s:Transition>
          </s:transitions>
          <s:states>
              <s:State name="up"/>
              <s:State name="over"/>
              <s:State name="down"/>
              <s:State name="disabled"/>
          </s:states>
          <fx:Metadata>[HostComponent("spark.components.Button")]</fx:Metadata>
          <s:BitmapImage source="@Embed('/assets/WolfMotive/Welcome_Mouse_Over.png')" resizeMode="scale" d:userLabel="Welcome Mouse Over" includeIn="down,over" id="bitmapimage1" y.down="2" visible.down="false"/>
          <s:BitmapImage source="@Embed('/assets/WolfMotive/Welcome_Mouse_Up.png')" resizeMode="scale" d:userLabel="Welcome Mouse Up" visible.over="false" id="bitmapimage2" x="4" y="9" y.down="11"/>
      </s:Skin>
      I need to know where this code (if it can) goes to make the button link -this is what one person told me
      So, you could do the following:
      <s:Button click="handleClick()"/>
      Next, add a script block to your application, after </fx:DesignLayer> and before </s:Application>, which looks like this:
      <fx:Script>
      <![CDATA[
      protected function handleClick():void
           navigateToURL( new URLRequest("http://www.adobe.com"), "_self");
      </fx:Script>
      So I'm lost as to where this should go in this section.
      Cause unless I'm that much of a noob (which I may be), I'm not sure if it can go in here at all.
      The original code was set up to go in this code -
      <s:Application
              width="720" height="50" backgroundColor="#000000">
          <s:BitmapImage source="@Embed('/assets/WolfMotive/Top_Menu_Bar.png')" resizeMode="scale" d:userLabel="Top Menu Bar" x="-1" y="-12"/>
          <fx:DesignLayer d:userLabel="Text Top Mouse Ove">
          </fx:DesignLayer>
          <fx:DesignLayer d:userLabel="Text Top Mouse Up">
              <s:Button x="583" y="12" skinClass="components.Button5" d:userLabel="Contacts Button"/>
              <s:Button x="433" y="12" skinClass="components.Button4" d:userLabel="Portfolios Button"/>
              <s:Button x="303" y="12" skinClass="components.Button3" d:userLabel="Projects Button"/>
              <s:Button x="154" y="12" skinClass="components.Button2" d:userLabel="Bios Button"/>
              <s:Button x="27" y="12" skinClass="components.Button1" d:userLabel="Welcome Button"/>
          </fx:DesignLayer>
      </s:Application>
      Please help...again.
