0 Replies Latest reply on Aug 17, 2009 4:51 PM by deepa subramaniam (adobe)
    [svn:fx-trunk] 9358: More work to support FXG 2. 0 in the MXML Graphics library.
    deepa subramaniam (adobe) Level 2
      Revision: 9358
      Author:   dsubrama@adobe.com
      Date:     2009-08-17 16:51:20 -0700 (Mon, 17 Aug 2009)
      Log Message:
      More work to support FXG 2.0 in the MXML Graphics library.
      1. Switch blendMode default from layer to normal. Before, we did some trickery under the covers, where even though the default blendMode was layer, we actually only set it to layer when it resulted in a rendering difference (ie: when alpha was > 0 < 1 and other overlapping cases). Now, FXG 2.0 mandates blendMode default is normal ?\226?\128?\147 and we don?\226?\128?\153t have to do that trickery because the FXG exporters are smarter and will set blendMode explicitly to layer when necessary. This change is for Group and all graphic primitives.
      2. I?\226?\128?\153ve added new enumerations to blendMode and maskType as well as a couple of new properties as mandated by FXG 2.0. There is additional work that needs to happen there that I?\226?\128?\153ll be doing next week.
      3. I?\226?\128?\153ve renamed Group?\226?\128?\153s resizeMode enumerations from ?\226?\128?\152normal?\226?\128?\153, ?\226?\128?\152scale?\226?\128?\153 to ?\226?\128?\152noScale?\226?\128?\153, ?\226?\128?\152scale?\226?\128?\153.
      4. I?\226?\128?\153ve renamed BitmapImage?\226?\128?\153s resizeMode enumerations from ?\226?\128?\152normal?\226?\128?\153, ?\226?\128?\152scale?\226?\128?\153, ?\226?\128?\152repeat?\226?\128?\153 to ?\226?\128?\152noScale?\226?\128?\153, ?\226?\128?\152scale?\226?\128?\153, ?\226?\128?\152repeat?\226?\128?\153. The default value for BitmapImage.resizeMode went from ?\226?\128?\152repeat?\226?\128?\153 to ?\226?\128?\152scale?\226?\128?\153. Additionally, BitmapImage.repeat property has now been eliminated - use resizeMode="repeat".
      5. I?\226?\128?\153ve deprecated BitmapFill?\226?\128?\153s ?\226?\128?\152repeat?\226?\128?\153 property. I?\226?\128?\153ve added a ?\226?\128?\152resizeMode?\226?\128?\153 property to BitmapFill with the same enumerations, defaults and behavior as BitmapImage. I?\226?\128?\153ve also moved BitmapImageResizeMode from spark.primitives to mx.graphics. I?\226?\128?\153ve also renamed BitmapImageResizeMode.as to BitmapResizeMode.as (a PARB-approved rename).
      QE notes:  Yes! Joan and I have cycloned numerous times and QA in on-board with the changes.
      Doc notes: Yes
      Bugs: Several
      Reviewer: Evtim/Glenn
      Tests run: Pretty much the entire mustella run for Halo and Spark components
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/frameworks/halo-manifest.xml
          flex/sdk/trunk/frameworks/mxml-manifest.xml
          flex/sdk/trunk/frameworks/projects/airframework/spark-air-manifest.xml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/CloseB uttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/Grippe rSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacClo seButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacMax imizeButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacMin imizeButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacTit leBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/Maximi zeButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/Minimi zeButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/Restor eButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/TitleB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFill.as
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/examples/BitmapImag eExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ResizeMode.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/MaskType.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/BitmapImage.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/RadioButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextAreaSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextInputSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ToggleButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ComboBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarDownButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarUpButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperDecrButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperIncrButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/DropDownListSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HScrollBarSkin.mxm l
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/NumericStepperSkin .mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/RadioButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/SpinnerSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ToggleButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VScrollBarSkin.mxm l
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VSliderSkin.mxml
          flex/sdk/trunk/frameworks/spark-manifest.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapResizeMode.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/BitmapImageResizeMode.as
