1. Re: can't open CS3 docs in CS4.
P Spier Aug 18, 2009 4:44 AM (in response to therayman)Older docs should open just fine.
What is the file extension on the document you are having trouble with? How are you trying to open (Double-click, File > Open)? Do you get an error message?
Is this isolated to older docs in general, specific docs, or are you also unable to sve and reopen a new file?
What is the installation path you used for ID (what folder is it inistalled into)?
2. Re: can't open CS3 docs in CS4.
therayman Aug 18, 2009 2:00 PM (in response to P Spier)I think I may have solved the problem although I have no idea why there is
one. It appears to be a problem with opening files from my file server but
only the first time. If I move the docs to the local machine I am working on
they open OK and I can then save and re-open to and from the server?
3. Re: can't open CS3 docs in CS4.
P Spier Aug 18, 2009 2:37 PM (in response to therayman)I don't have an expalnation for why, but network problems are not uncommon. Could be the time is out of synch.
