2 Replies Latest reply on Aug 18, 2009 7:10 AM by AB_Jeroen
    lock transparancy layer color
      Hi all,
      I created a layer over the entire workarea with a yellow color. I set the transparancy to 10%. It overlay's a blank white backround, so I get a subtle yellow background color.
      I placed 2 pictures on top of the 'background-yellow-layer' . These pictures overlap, so I wanted to put a rectangle with the same color as the background-yellow in between the pictures. That way I create a border around one image, but the border has the exact same color as the background.
      I can't do this. Because when I overlap 2 layers with yellow 10% transparancy, the color gets darker where the layers overlap. (2 times 10% yellow).
      Now I wan't the color code of the yellow while it's transparant, so I can apply that specific color without transparancy. Can anyone tell me how to achive this?
        • 1. Re: lock transparancy layer color
          Wade_Zimmerman Level 6
          You're going about it the wrong way. either pick a color tat is already a light yellow either in the swatch panel or from the color panel's picker and make a swatch of that color and you might turn that into a global color as well and color both the background rectangle and the overlapping rectangle/
          I am not certain there is a reason for an overlapping rectangle either. But certainly no need for the white filled rectangle.
          Or you could if you need to make it complex, select a darker yellow turn it into a global swatch and reduce the tint percentage in the color panel.
          Use the for the background yellow and the overlapping yellow rectangle.
          But I think you should post a screen shot of what you have and want to do as it seems unnecessarily complex.
          • 2. Re: lock transparancy layer color
            AB_Jeroen Level 1
            tnx for your reply. From the color panel I could select a yellow color between pure yellow and white. That way I could make a light-yellow color without using transparancy! Added that one to my swatchlist, so it's working now
