I've looked through the code provided on these forums and even copied examples over but my cflogin tag still returns the user back to the login page. When I test cflogin not in the application.cfc file (with the cflogin on a page by itself) it seems to work fine. Can someone provide a second pair of eyes to see where I'm missing something. In the URL it is getting the CFID and CFTOKEN -here's the returned URL after logging in "
mywebsite/home.cfm?CFID=717&CFTOKEN=93369078
This is the application.cfc file:
<cfcomponent>
<cfset This.name = "myapp">
<cfset This.Sessionmanagement="true">
<cfset This.Sessiontimeout="#createtimespan(0,0,30,0)#">
<cfset This.applicationtimeout="#createtimespan(1,0,0,0)#">
<cffunction name="onRequestStart">
<cfargument name = "request" required="true"/>
<cfif IsDefined("Form.logout")>
<cflogout>
</cfif>
<cflogin>
<cfif NOT IsDefined("cflogin")>
<cfinclude template="login.cfm">
it's here
<cfabort>
<cfelse>
<cfquery name="loginQuery" dataSource="#mysource#">
select id,passwd, manager_level from personal
where emplid = '#cflogin.name#'
AND passwd = '#cflogin.password#'
and manager_level <> '8'
</cfquery>
<cfif loginQuery.manager_level NEQ "">
<cfloginuser name="#cflogin.name#" Password = "#cflogin.password#"
roles="#loginQuery.manager_level#">
<cflocation url="home.cfm">
<cfelse>
<cfoutput>
<H2>Your login information is not valid.<br>
Please Try again</H2>
</cfoutput>
<cfabort>
</cfif>
</cfif>
</cflogin>
</cffunction>
</cfcomponent>
And my login form =
<form method="post" action="home.cfm">
ID: <input type="text" name="j_username" size="3" max="11">
password: <input type="text" name="j_password" size="8" max="11">
<input type="submit" name="action" value="Proceed">
I've semi fixed the problem. It now lets the user get to the home page but it doesn't appear to be setting the <cfloginuser> variables such as name, password and rolls.
Under the <cflogin> tag I changed the <cfif Not IsDefined("cflogin")> to <cfif NOT IsDefined("form.j_username")>
The example in the documents use the <cfif Not IsDefined("cflogin")> approach but it didn't work for me.
How do you get the variables from cfloginuser or make sure they are set? When using #GetAuthUser()# I do get the j_username but #cflogin.name# or #GetUserRoles()# gives me an error - Variable GetUserRolls is undefined.
Thanks for the help
