0 Replies Latest reply on Aug 19, 2009 2:56 AM by GhostBob2
    AS 2: font from shared library
    GhostBob2
      Need to load font from shared library, to use it in main application then needed.
      Problem - do not work in IE7 and IE8. all working fine in FF. Problem it'self: code from loaded swf do not run.
      Explanation:
      file: arial_n_lib.fla - on the stage (main scene) movieClip - arial_n_mc. It contains dynamic textfield with needed Font-Arial and Embeded symbols(cyrilic, latin etc...). MovieClip properties: in first frame, for action script, export for runtime sharing and swf path
      file: arial_n.fla - shared library container: on the stage (main scene) movieClip- arial_n_mc (dragged from arial_n_lib.fla ). On the next layer AS2.0 code:
      this.TimeOut = function()
      if(this.id == undefined)
      this.id = setInterval(this,"TimeOut",1000);
      else
      clearInterval(this.id );
      trace("registering txt field::"+this.arial_n_mc.arial_n_txt)
      _global.regFont(this.arial_n_mc.arial_n_txt);
      this.TimeOut();
      file: ie8test.fla - main app(test). Code in fla (showing here main parts - do not show trivial things)
      my_mcl.addListener(myListener);
      my_mcl.loadClip(myURL, this.dummy);
      _global.regFont = function(tfld) //tfld - Textfield object
      var tf = tfld.getTextFormat();
      trace("font="+tf.font)
      so loading shared libary container. In FF I see trace: font=Arial, in IE7,8 - function regFont did not called. Why??
      Please help, it's very urgent! Big project stopped because of this
      P.S. changing _global.regFont to _root.regFont - does not help
      P.P.S. compiled for player version 9 and 10. Played in FlashPlayer v10 - no results
