3 Replies Latest reply on Aug 20, 2009 1:31 AM by gibbetnet
    Basic problems with extension of IEventDispatcher in application
    gibbetnet
      Hi at All!
      I’ve got a general problem to create a MVC-Pattern, because the FlexBuilder throw an error message in the “Problems”-Box when I try to add an eventlistener to the model.  I do not understand why it is so and hope, that somebody could explain me what’s wrong in my code. The error message is
      “1195: Versuchter Aufruf der nicht verfügbaren Methode addEventListener über einen Verweis mit statischem Typ MainFile”,
      which means, that I tried to call a not available method addEventListener via a reference of static type MainFile. In the following code I give a short exampl, which generated the error message in the FlexBuilder.
      The basic Interface is a very simple extension of the IEventDispatcher. The Code is:
      package model.interfaces
            import flash.events.IEventDispatcher;
            public interface IMapModel extends IEventDispatcher
                  function getKey(node:XML):String;
      The MapModel class extends EventDispatcher and implements the IMapModel. The Code is:
      package model
            import flash.events.EventDispatcher;
            import flash.events.Event;
            import model.interfaces.IMapModel;
            public class MapModel extends EventDispatcher implements IMapModel
                  public function MapModel(target:IEventDispatcher=null)
                        super(target);
                  public function getKey(node:XML):String
                        return "Key";
      In the MainFile, which is an mxml-Application, I get the error-message in the init-method. The Code here is:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
            <mx:Button label="TEST"  x="402" y="151" click="this.test()"/>
            <mx:Script>
                  <![CDATA[
                        import mx.controls.Alert;
                        import model.MapModel;
                        private var model:IMapModel;
                        private function test():void
                              this.model = new MapModel();
                              this.model.addEventListener(Event.CHANGE,this.testAlert);
                              this.model.dispatchEvent(new Event(Event.CHANGE));
                        private function testAlert(e:Event):void
                              Alert.show("TEST");
            </mx:Script>
      </mx:Application>
      When I start to run the application FlexBuilder tell me, that an error exist in required project and ask, if it proceed with launch. When I proceed, all works fine (which means that the Alert occurs after clicking the Test-Button) in spite of the warning from FlexBuilder. So.. why it warning??? Whats wrong? It is really a miracle for me…
      By the way:
      When you replacing the lines
      in the init-method by the following lines:
      (this.model as IEventDispatcher).addEventListener(Event.CHANGE,this.testAlert);
      (this.model as IEventDispatcher).dispatchEvent(new Event(Event.CHANGE));
      no more error message occurs in the FlexBuilder. But… why I have to declare explicit this.model as IEventDispatcher when it is a IMapModel (which extend the IEventDispatcher)??? Why it does not inherit the methods of the IEventDispatcher directly???
      Thanks for reading this long description ;o),
      Isabel
