1 Reply Latest reply on Aug 20, 2009 10:43 AM by Jeff Swartz
    AIR not accessing online Javascript library?? HELP PLS SOMEONE!!!
    IrishAIRMax Level 1
      Hi everyone,
      I have air app which I am trying to connect with the yahoo/bing maps api (javascript library)
      But i keep on getting reference errors as if the AIR app is not retreiving the yahoo/bing map libraries?
      Or is it that these Javascript libraries have to be saved somewhere special as the app cannot use tham when they are in a certain sandbox?
      I don't know and the is wrecking my head! Both working in normal html page through dreamweaver.... so they should work in AIR, but they don't, the code is:
      <head>
      <script type="text/javascript"
      src="http://api.maps.yahoo.com/ajaxymap?v=3.8&appid=myappid"></script>
      <script type="text/javascript" src="http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.2"></script>
      <style type="text/css">
      #yahooMap{
      height: 100%;
      width: 50%;
      float:left;
      #bingMap{
      height: 100%;
      width: 50%;
      float:left;
      </style>
      </head>
      <body>
      <div id="yahooMap"></div>
      <div id="bingMap"></div>
          // Create a map object
          var map = new YMap(document.getElementById('yahooMap'));
          var bmap = new VEMap('bingMap');
          // Add map type control
          map.addTypeControl();
          // Set map type to either of: YAHOO_MAP_SAT, YAHOO_MAP_HYB, YAHOO_MAP_REG
          map.setMapType(YAHOO_MAP_REG);
            var farinefive = new VELatLong(45.5, -73.54);
            bmap.LoadMap(farinefive, 17);
          // Display the map centered on a geocoded location
          map.drawZoomAndCenter("San Francisco", 3);
      </script>
      </body>
      </html>
      The error are :
      "ReferenceError: Can't find variable: YMap"
      "ReferenceError: Can't find variable: VELatLong"
      "ReferenceError: Can't find variable: VEMap"
      Thank you all in advance
      IrishAIRMax
