2 Replies Latest reply on Aug 19, 2009 9:18 AM by the_wine_snob
    make mpeg-4 -ts
      I wanna export a file with this specifications from the Premiere CS4
      software, but there in the Premiere I cannot find these specifications,
      please send me a VPR or EPR file with these specifications.
      I really appreciate it
      Format                           : MPEG-4  -TS
      Format                           : AVC
      Format/Info                      : Advanced Video Codec
      Format profile                   : Main@L3.1
      Codec ID/Info                    : Advanced Video Coding
      Bit rate mode                    : Constant
      Bit rate                         : 8000 kbps
      Width                            : 720 pixels
      Height                           : 576 pixels
      Aspect ratio    : 4/3
      Frame rate mode                  : Constant
      Frame rate                       : 25.000 fps
      Standard                         : PAL
      Scan type                        : Interlaced
      Scan order                       : (Top Field First)
      Format                           :  MPEG Audio
      Format/Info                      : Mpeg-1 Layer II
      Bit rate mode                    : Constant -
      Bit rate                         : 192 Kbps
      Channel(s)                       : 2 channels
      Channel positions                : L R
      Sampling rate                    : 48.0 KHz
        • 1. Re: make mpeg-4 -ts
          Jim_Simon Level 8
          I'm not sure you can do this with Premiere.  H.264 and AVC are the same thing, so you'd start with an H.264 option.  Most of what you need is possible, but it falls down with the audio.  I see only DD, PCM and AAC options possible, no MPEG1, Layer II.
          There also may be a catch trying to create a transport stream.  The "H.264" option will produce MP4 files, (no .ts), and the "H.264 Blu-ray" option is likely to produce program stream files (nevber tried it, though).
          • 2. Re: make mpeg-4 -ts
            the_wine_snob Level 9
            You might want to look into this H.264 CODEC, from MainConcept. It might allow you to get that MPEG Audio, but still do not know about the TS wrapper. I'd e-mail their Tech Support for clarification.
