Hi
I need to attach original powerpoint presentation to let the users download it from Presenter presentation. I added the file into [presentationName]/data/resources/[fileName.ppt] but when I publish the presentation and want to download the original PowerPoint presentation nothing happens. Why? What can be a source of the problem? How can I solve it??
Thank in advance
Hi ,
I have tried locally in Firefox and it downloads presentation which is an attachment . In IE , it is not doing anything though .But on hosting it on a web server, it downloads the presentation with both the browsers .
Also , you need not paste the presentation manually . You can add it as an attachment using Adobe Presenter > Presentation Settings
-Thanks
Leo
Hi ,
-Thanks
Leo
thanks once again. That solved my issue.
I believe I am experiencing a similar problem. I am using Presenter 7 and trying to attach several documents and web sitec links. I go to the Settings tab and click on Attachments. I click on Add and add several files as well as web addresses. When I publish the PPT and the attachments show when I click on the paperclip but when I click on either a file or web site address nothing happens.
I have attached the results on both files and links. Thank you in advance with your response. . you can sendcresponse to john.mccrudden@asu.edu
