0 Replies Latest reply on Aug 19, 2009 8:55 AM by Carol L. Frampton
    [svn:fx-trunk] 9385: SkinnableTextBase. as - remove code to redispatch UPDATE_COMPLETE event from RET.
    Carol L. Frampton Level 2
      Revision: 9385
      Author:   cframpto@adobe.com
      Date:     2009-08-19 08:54:55 -0700 (Wed, 19 Aug 2009)
      Log Message:
      SkinnableTextBase.as - remove code to redispatch UPDATE_COMPLETE event from RET.  For each property setter, even though they are just proxies to RET, call invalidateProperties() to generate UPDATE_COMPLETE events and add handler for the TextOperationEvent.CHANGE and call invalidateDisplayList() to generate UPDATE_COMPLETE events for RET size and display list changes.  SDK-22705
      TextArea.as - remove code to set scroller horizontalScrollPosition to off if "toFit".  Need to do it "virtually" rather than actually change the scroller property.  SDK-22680
      RichEditableText.as
      Changes to rememasureText() and measure() since not all combinations of constrainted width/height worked correctly, particularly if auto sizing.  SDK-22727
      Changes to textContainerManager_compositionCompleteHandler() to try to keep "contentWidth" seen by scroller constant if lineBreak="toFit" so the scroller doesn't think it needs to add a horizontal scroll bar.  If the text is "toFit" there should never be a hsb.  SDK-22680
      Change to updateDisplayList() to scroll after updating the container if it was delayed when EditManager.updateAllContainers() last ran. SDK-22705
      Removed default params from scrollToRange() since they don't make sense.  SDK-22696.
      Some cleanup based on TLF cleanup.
      RichEditableTextContainerManager.as - in drawBackgroundAndSetScrollRect(), if auto sizing, should use the display list width and height for the scroll rect and background for the text rather than the content width and height.   SDK-22727 and SDK-22678 ended up fixed too.
      RichEditableTextEditManager.as - flag to know if scroll is needed after updating the container in updateDisplayList.  SDK-22696
      QE notes: be sure to make automated tests for SDK-22727, SDK-22705, SDK-22678 please
      Doc notes:
      Bugs: SDK-22727, SDK-22626, SDK-22680, SDK-22705, SDK-22696, SDK-22678
      Reviewer: Gordon
      Tests run: basictests, checkintests, TextArea, TextInput, NumericSteeper
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22705
          http://bugs.adobe.com/jira/browse/SDK-22680
          http://bugs.adobe.com/jira/browse/SDK-22727
          http://bugs.adobe.com/jira/browse/SDK-22696
          http://bugs.adobe.com/jira/browse/SDK-22678
          http://bugs.adobe.com/jira/browse/SDK-22626
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TextArea.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableTex tBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/RichEditable TextContainerManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/RichEditable TextEditManager.as
