4 Replies Latest reply on Aug 19, 2009 2:30 PM by John Joslin
    Profile Mismatch with RAW
    Don4444 Level 1
      I recently began shooting in RAW, using a Canon 40D.  I do not use the Canon-provided DPP, instead I use Photoshop CS4 Bridge (3.0.0.464), Camera Raw (5.4), and Photoshop CS4 (11.0.1).  I believe that I am suffering from a profile mismatch.  After completing my work in Camera Raw I click the “Open Image” button, which opens the image in Photoshop.  There, the window’s title bar reads “Photo Name.dng@25% (RGB/8*)”.  It is my understanding that the asterisk after the 8 indicates that a profile mismatch exists.  When using this same software and equipment, but shooting JPEGs instead of RAW, I did not get this asterisk.
      When looking at a RAW image, the metadata in Bridge provides this info:
      Document Type:              DNG image
      Bit Depth:                            16
      Color Mode:                       RGB
      Color Profile:                      Untagged
      When looking at a JPEG image, the metadata in Bridge provides this info:
      Document Type:              JPEG file
      Bit Depth:                            8
      Color Mode:                       RGB
      Color Profile:                      sRGB IEC61966-2.1
      Photoshop (edit>color settings) provides this info:
      Settings:                              North America General Purpose 2
      Working Space:                 RGB sRGB IEC61966.21
      Color Management Policies:       RGB Preserve Embedded Profiles
        Profile Mismatches:  No boxes are checked
      My primary output is to a inkjet printer. I have searched various forums and read some Adobe white papers, in search of answers, but still need help.
      Here are my questions:
      1.       How do I correct this profile mismatch?
      2.       Should I be using a bit depth of 16 or 8?
      3.       If I should be changing the bit depth, how do I do that?
      Thanks for your help.
        • 1. Re: Profile Mismatch with RAW
          JimHess-5IFZWq Level 3
          I might be wrong, but I think the asterisk simply means that what you are seeing in the image needs to be saved.
          • 2. Re: Profile Mismatch with RAW
            Jeff Schewe Level 5
            In Camera Raw, what working space do you have it set for processing? If Camera Raw and Photoshop are both set to sRGB, you don't have a profile mismatch. If Camera Raw is set for any other space and Photoshop is set for sRGB then yes you have a mismatch. So, what is Camera Raw set to open as?
            • 3. Re: Profile Mismatch with RAW
              Don4444 Level 1
              Yep, that's the answer.  I didn't realize that I had a choice regarding color profile in Camera RAW.  I looked around and discovered that the thing under the photo that looks like a web link brings me to a place where I can choose the color profile.  And, you are correct.  There was a discrepancy between the profile that was in Camera RAW and the profile that was in PS.  A couple of clicks of the mouse and the problem has been solved.  Thanks for your help!!!
              • 4. Re: Profile Mismatch with RAW
                John Joslin Level 6
                Don4444 wrote:
                ... the thing under the photo that looks like a web link brings me to a place where I can choose the color profile.
                I still don't undersand why that "thing" can't be a button.
                It fools loads of people.
