5 Replies Latest reply on Aug 19, 2009 2:49 PM by Gregory Lafrance
    Any sleep/pause/wait function in flex/AS
    AmitVyawahare
      I am new to flex and this forum. So can anyone tell me how to produce a delay in my program. I just need 3 second delay in my program.
      I just need to write a delay function. The function look like..
      private function delay():void
           // 3 second delay code
      Thank you,
      --Amit
        • 2. Re: Any sleep/pause/wait function in flex/AS
          AmitVyawahare Level 1
          I tryed this stuff before but i am not able to get that delay. I think i am doing some thing wrong. It will not take more than 3 line of code to create delay.
          Can you please code for me. thank you.
          --Amit
          • 3. Re: Any sleep/pause/wait function in flex/AS
            Gregory Lafrance Level 6
            If this post answered your question or helped, please mark it as such.
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
              creationComplete="init();">
              <mx:Script>
                <![CDATA[
                  private var myTimer1:Timer;
                  private var myTimer2:Timer;
                  [Bindable] private var num1:uint = 0;
                  [Bindable] private var num2:uint = 0;
                  private function init():void{
                    myTimer1 = new Timer(3000, 1);
                    myTimer1.addEventListener(TimerEvent.TIMER_COMPLETE, timerHandler1);
                    myTimer1.start();
                    myTimer2 = new Timer(1000, 0);
                    myTimer2.addEventListener(TimerEvent.TIMER, timerHandler2);
                    myTimer2.start();
                  public function timerHandler1(event:TimerEvent):void {
                    num1++;
                  public function timerHandler2(event:TimerEvent):void {
                    num2++;
              </mx:Script>
              <mx:Label id="lbl_1" fontSize="40" text="{String(num1)}"/>
              <mx:Label id="lbl_2" fontSize="40" text="{String(num2)}"/>
            </mx:Application>
            • 4. Re: Any sleep/pause/wait function in flex/AS
              This is helpful but problem is how do i know when that 3 second will finish.
                      myTimer1.start();
                      num1++;
              I want to insert a function when that 3 second finish. The function name is check(). Where should i put this check function.
              My aim is when that 3 second finish i want to call check() function.
              --AMit
              • 5. Re: Any sleep/pause/wait function in flex/AS
                  <mx:Script>
                    <![CDATA[
                        myTimer1.start();
                        check();
                      public function check():void {
                        lbl_1.text = "check() function called.";
                  </mx:Script>
                  <mx:Label id="lbl_1" fontSize="40" text="waiting"/>
                </mx:Application>
