2 Replies Latest reply on Aug 19, 2009 2:37 PM by GeorgeWS
    Advanceddatagrid problem
    GeorgeWS Level 1
      I have an app that has 2 unrelated ADG's they both get data from RO's/ArrayCollection's. The first ADG has grouping and Summing and works perfectly. The second ADG fills with data and when I press on a header to sort it all the data dissapears. This grid has no grouping so I could try and debug easier but cannot seem to find the problem 2 days I have been trying different stuff. Any Thoughts
      George
        • 1. Re: Advanceddatagrid problem
          Gregory Lafrance Level 6
          For this we'll need to see simplified yet complete code and data sample.
          • 2. Re: Advanceddatagrid problem
            GeorgeWS Level 1
            This is my application:
            <mx:Application
            xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="initVars()" layout="absolute"
            <mx:Script>
            <![CDATA[
            import
            mx.rpc.events.ResultEvent;
            import
            mx.controls.Alert;
            import
            mx.collections.ArrayCollection;
            import
            mx.core.Application;
            import
            mx.utils.ObjectUtil;
            import
            mx.core.IUIComponent;
            import
            mx.events.SliderEvent;
            import
            mx.controls.sliderClasses.Slider;
            Bindable] public var
            myRac:ArrayCollection;
            myDep:ArrayCollection;
            myDates:ArrayCollection;
            SupplierID:String;
            BrandID:String;
            SupComp:String;
            myRegion:String;
            mySummary:Boolean;
            thumbTwoA:String;
            thumbTwoB:String;
            Bindable] public var aReturnTypes: Array = [ {label:"query", data:"query"
            Bindable] public var returnType:String="string"
            public function handleQueryResult(event:ResultEvent):void
            myRac=event.result
            as
            ArrayCollection;
            myRac.filterFunction = sliderFilterFunc;
            gc.refresh();
            public function handleQueryResult5(event:ResultEvent):void
            myDep=event.result
            as
            ArrayCollection;
            myDep.filterFunction = sliderFilterFunc;
            selectedItem:Object;
            public function initVars() : void
            SupplierID = Application.application.parameters.SupplierID;
            BrandID = Application.application.parameters.BrandID;
            SupComp = Application.application.parameters.SupComp;
            qRac.Rac(SupplierID, BrandID, SupComp);
            qDep.Dep(SupplierID, BrandID, SupComp);
            Brands.Brands.send();
            Dates.Dates.send();
            Bindable] private var newBrands:ArrayCollection=new
            ArrayCollection;
            public function
            doPrompt( event:ResultEvent
            void
            newBrands = Brands.Brands.lastResult;
            var prompt:Object = new
            Object();
            prompt.data =
            null
            prompt.label =
            "Select Brand"
            newBrands.addItemAt( prompt, 0 );
            brandfilter.selectedIndex = 0;
            public function slider_change(evt:SliderEvent):void
            gc.refresh();
            myDep.refresh();
            public function
            sliderFilterFunc(item:Object):Boolean {
            var
            minSlider:uint = slider.values[0];
            var
            maxSlider:uint = slider.values[1];
            if
            ((item.value >= minSlider) &&
            (item.value <= maxSlider)) {
            return true
            else
            return false
            public function doPrompt3( event:ResultEvent ):void
            myDates = Dates.Dates.lastResult;
            private function
            getSliderLabel(value:String):String
            return
            myDates[parseInt(value)].myDates;
            </mx:Script>
            <mx:RemoteObject
            id="
            qRac
            destination="
            ColdFusion
            source="
            youngsmarket.programs.racdepletion.racdepletion.bin-debug.racdepletion
            showBusyCursor="
            true" >
            <mx:method name="Rac
            " result="handleQueryResult(event)"
            fault="Alert.show(event.fault.message)"
            <mx:arguments>
            <supplierid>{SupplierID}
            </supplierid>
            <brandid>{BrandID}
            </brandid>
            <supcomp>{SupComp}
            </supcomp>
            </mx:arguments>
            </mx:method>
            </mx:RemoteObject>
            <mx:RemoteObject
            id="
            qDep
            destination="
            ColdFusion
            source="
            showBusyCursor="
            true" >
            <mx:method name="Dep
            " result="handleQueryResult5(event)"
            <mx:arguments>
            </supplierid>
            <brandid>{BrandID}
            </brandid>
            <supcomp>{SupComp}
            </supcomp>
            </mx:arguments>
            </mx:method>
            </mx:RemoteObject>
            <mx:RemoteObject
            id="
            Brands
            destination="
            ColdFusion
            source="
            showBusyCursor="
            true" >
            <mx:method name="Brands" result="doPrompt( event )"
            <mx:arguments>
            </supplierid>
            <brandid>{BrandID}
            </brandid>
            <supcomp>{SupComp}
            </supcomp>
            </mx:arguments>
            </mx:method>
            </mx:RemoteObject>
            <mx:RemoteObject
            id="
            Dates
            destination="
            ColdFusion
            source="
            showBusyCursor="
            true" >
            <mx:method name="Dates" result="doPrompt3( event )"
            </mx:RemoteObject>
            <mx:Panel title="RAC/Depletion" height="100%" width="100%
            paddingTop="
            5" paddingLeft="5" paddingRight="5" paddingBottom="5" cornerRadius="10" roundedBottomCorners="true" top="0" bottom="0" left="0" right="0" borderColor="#7A909B" backgroundColor="#96A7AF"
            <mx:HBox
            width="100%"
            <mx:ComboBox id="brandfilter" dataProvider="{newBrands}
            labelField="
            label" width="120
            close="selectedItem=ComboBox(event.target).selectedItem"
            change="gc.refresh();myDep.refresh()" themeColor="
            #73B9B9"
            <mx:HSlider id="slider
            minimum="
            1
            maximum="
            12
            values="
            [1,12]
            labels="
            [Jan,Dec]
            thumbCount="
            2
            showTrackHighlight="
            true
            snapInterval="
            1
            tickInterval="
            1
            liveDragging="
            true
            change="slider_change(event);"
            dataTipFormatFunction="
            getSliderLabel" themeColor="#73B9B9"
            <mx:RadioButtonGroup id="myReport"/>
            <mx:RadioButton groupName="myReport" label="RAC
            click="accordion.selectedIndex=0;" selected="
            true" width="50" themeColor="#73B9B9"
            <mx:RadioButton groupName="myReport" label="Dep
            click="accordion.selectedIndex=1;" width="
            <mx:Spacer width="100%"
            <mx:CheckBox id="mySum" label="Sum Region" selected="true
            width="
            96" themeColor="#73B9B9"
            </mx:HBox>
            <mx:Accordion
            id="accordion" width="100%" height="100%
            headerHeight="
            5" themeColor="#73B9B9"
            <mx:VBox
            width="100%" height="100%" >
            <mx:AdvancedDataGrid id="myDataGrid" width="100%
            height="
            100%" themeColor="#73B9B9"
            <mx:dataProvider>
            <mx:GroupingCollection id="gc" source="{myRac}"
            <mx:Grouping>
            <mx:GroupingField name="myHeader"
            <mx:SummaryRow summaryPlacement="group"
            <mx:fields>
            <mx:SummaryField dataField="PCTONU" operation="SUM" label="PCTONU"
            <mx:SummaryField dataField="PCCHNU" operation="SUM" label="PCCHNU"
            <mx:SummaryField dataField="PCNFNU" operation="SUM" label="PCNFNU"
            <mx:SummaryField dataField="PCCONU" operation="SUM" label="PCCONU"
            <mx:SummaryField dataField="PCMINU" operation="SUM" label="PCMINU"
            <mx:SummaryField dataField="PCONNU" operation="SUM" label="PCONNU"
            <mx:SummaryField dataField="PCNONU" operation="SUM" label="PCNONU"
            <mx:SummaryField dataField="PCTRNU" operation="SUM" label="PCTRNU"
            <mx:SummaryField dataField="PCINNU" operation="SUM" label="PCINNU"
            <mx:SummaryField dataField="PCWHNU" operation="SUM" label="PCWHNU"
            </mx:fields>
            </mx:SummaryRow>
            </mx:GroupingField>
            </mx:Grouping>
            </mx:GroupingCollection>
            </mx:dataProvider>
            <mx:groupedColumns>
            <mx:AdvancedDataGridColumn
            dataField="myHeader" headerText="Product
            minWidth="
            75"
            dataField="value" headerText="Month
            minWidth="
            20"
            dataField="SDIVDE" headerText="Size
            minWidth="
            50"
            dataField="ISCF5W" headerText="Pac" minWidth="20"
            dataField="PCTONU" headerText="Sales
            textAlign="
            right" minWidth="26" itemRenderer="NumberItemRenderer"
            dataField="PCCHNU" headerText="Chain
            textAlign="
            right" minWidth="50" itemRenderer="NumberItemRenderer2"
            dataField="PCNFNU" headerText="Nat Off Prem
            textAlign="
            right" minWidth="50" itemRenderer="NumberItemRenderer3"
            dataField="PCCONU" headerText="Convin
            textAlign="
            right" minWidth="50" itemRenderer="NumberItemRenderer4"
            dataField="PCMINU" headerText="Military
            textAlign="
            right" minWidth="50" itemRenderer="NumberItemRenderer5"
            dataField="PCONNU" headerText="On Prem
            textAlign="
            right" minWidth="50" itemRenderer="NumberItemRenderer6"
            dataField="PCNONU" headerText="Nat On Prem
            textAlign="
            right" minWidth="50" itemRenderer="NumberItemRenderer7"
            dataField="PCTRNU" headerText="Trans
            textAlign="
            right" minWidth="50" itemRenderer="NumberItemRenderer8"
            dataField="PCINNU" headerText="Indp
            textAlign="
            right" minWidth="50" itemRenderer="NumberItemRenderer9"
            dataField="PCWHNU" headerText="Whsl
            textAlign="
            right" minWidth="50" itemRenderer="NumberItemRenderer10"
            </mx:groupedColumns>
            </mx:AdvancedDataGrid>
            </mx:VBox>
            <mx:VBox
            <mx:AdvancedDataGrid id="theDataGrid" width="100%" dataProvider="{myDep}" height="100%"
            <mx:columns>
            dataField="theHeader" headerText="Product
            minWidth="
            75"
            minWidth="
            20"
            minWidth="
            50"
            dataField="DPBENU" headerText="Beg. Inv.
            textAlign="
            dataField="DPRENU" headerText="Receipt
            textAlign="
            dataField="DPTINU" headerText="TranfrIn
            textAlign="
            dataField="DPOUNU" headerText="TranfrOut
            textAlign="
            dataField="DPWHNU" headerText="WholeSale
            textAlign="
            dataField="DPSLNU" headerText="SaleTM
            textAlign="
            dataField="DPADNU" headerText="Adjust.
            textAlign="
            dataField="DPINNU" headerText="InTrans
            textAlign="
            dataField="DPENNU" headerText="End Inv.
            textAlign="
            dataField="DPCRNU" headerText="Cr/Db Adjust.
            textAlign="
            dataField="DPDPNU" headerText="Depletions
            textAlign="
            </mx:columns>
            </mx:VBox>
            </mx:Accordion>
            <mx:VBox width="100%"
            </mx:VBox>
            </mx:Panel>
            </mx:Application>
