Revision: 9399
Author: aharui@adobe.com
Date: 2009-08-19 13:39:10 -0700 (Wed, 19 Aug 2009)
Log Message:
Check in prototypes of ControlBars in Panel and Application, Spark Containers in Halo Navigators, Halo ViewStack in Spark ButtonBar. APIs should match spec but are subject to change from PARB. Skins are subject to tweaking after XD review
QE Notes: The following tests will fail and need updating:
gumbo/containers/Panel/Properties/Panel_Properties_position Panel_Properties_rotate
apollo/spark/components/Window/properties/window_properties_titleIcon_tests titleIcon_test8
Doc Notes: None
Bugs: None
Reviewer: Darrell, Glenn, Ryan
API Change: No
Is noteworthy for integration: No
tests: checkintests mustella/gumbo/components/Application, gumbo/components/ButtonBar, gumbo/containers/Panel, apollo/gumbo/spark/Window, containers/ViewStack, containers/Accordion,
Modified Paths:
flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/SparkChromeWindowedApplicationSkin.mxml
flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/TabNavigator.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/ViewStack.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/NavBar.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexEvent.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/FocusManager.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Application.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ButtonBar.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Panel.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/SkinnableContainer.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ApplicationSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/PanelSkin.mxml
flex/sdk/trunk/frameworks/spark-manifest.xml
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
Added Paths:
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IDeferredContentOwner.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/INavigatable.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/INavigatorContent.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/NavigatorChild.as
Removed Paths:
flex/sdk/trunk/frameworks/projects/spark/src/spark/core/IDeferredContentOwner.as
