4 Replies Latest reply on Aug 19, 2009 5:52 PM by Gregory Lafrance
    Event handler for a text field
    SiHoop Level 1
      How do I write an event handler that will be triggered when the value of a text field changes? I assume I can place an event in place of SOME EVENT HERE in the example below.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
              <![CDATA[
                  private var newVal:Number=1
                  public function doThis():void{
                      newVal+=1
                      goal1.text=String(newVal)
                      //goal1.addEventListener(SOME EVENT HERE, textChange)
                  public function textChange():void{
                      trace("text changed")
          </mx:Script>
          <mx:Text id="goal1" color="#57782f" fontSize="30" text="1"  x="106" y="110"/>
          <mx:Button x="88" y="169" label="Button" click="doThis()"/>
      </mx:Application>
        • 1. Re: Event handler for a text field
          Gregory Lafrance Level 6
          "Text" does not dispathc a change event, so use a TextArea tweaked as follows.
          If this post answered your question or helped, please mark it as such.
              <mx:Script>
                  <![CDATA[
                          newVal+=1
                          goal1.addEventListener(Event.CHANGE, textChange)
              </mx:Script>
              <mx:TextArea id="goal1" color="#57782f" fontSize="30" text="1"  x="106" y="110"
               focusThickness="0" borderThickness="0" backgroundAlpha="0"/>
          </mx:Application>
          • 2. Re: Event handler for a text field
            SiHoop Level 1
            I tried the code you posted, but the listener did not work. Would you please check the code you gave me to see if it works for you?
            Thanks.
            • 3. Re: Event handler for a text field
              SiHoop Level 1
              The event you gave me: goal1.addEventListener(Event.CHANGE, textChange)
              only works for user changed data. For programmatically changed data I had to use valueCommit:
              goal1.addEventListener("valueCommit", textChange)
              Thank you for your help.
              • 4. Re: Event handler for a text field
                That makes sense.
