2 Replies Latest reply on Aug 20, 2009 11:21 PM by Kurt Renfro
    Disappearing Subform
    Kurt Renfro Level 1
      I've created an interactive dynamic form that shows or hides subforms based on
      a selection from a drop-down menu.
      The drop-down menu has 10 "List Items" and each List Item has a corresponding subform.
      Each subforms presence set to "Hidden (Exclude from Layout)."
      The subforms are made "visible" or "hidden" using the following JavaScript:
      if ("RMC-Guernsey-PLD DOT" == xfa.event.newText)
          GU_ML.presence = "visible";
      else
          GU_ML.presence = "hidden";
          GU_ML.rawValue = "";
      This script is repeated 10 times, once for each list item and subform.
      The form fields are locked via a digital signature and the form is submitted as a PDF using an e-mail submit button.
      At this point everything looks fine.
      The problem is when the form is re-opened. The subform made visible from the drop-down menu is no longer
      visible, but is hidden and excluded from the layout.
      How do I keep the subform visible?
