0 Replies Latest reply on Aug 19, 2009 7:16 PM by Flex harUI
    [svn:fx-trunk] 9416: Revert 9399.
    Flex harUI Adobe Employee
      Revision: 9416
      Author:   aharui@adobe.com
      Date:     2009-08-19 19:15:38 -0700 (Wed, 19 Aug 2009)
      Log Message:
      Revert 9399.  The prototypes broke mustella states tests.  Will try again later.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/SparkChromeWindowed ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/TabNavigator.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/ViewStack.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/NavBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexEvent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/FocusManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Application.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Panel.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/SkinnableContainer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/PanelSkin.mxml
          flex/sdk/trunk/frameworks/spark-manifest.xml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/IDeferredContentOwner.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IDeferredContentOwner.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/INavigatable.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/INavigatorContent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/NavigatorChild.as
