5 Replies Latest reply on Aug 27, 2009 10:33 AM by Jasmin Charbonneau
    Convert XFA Form Variable into a PDF Doc.
    vicky_rulz
      Hello,
             I need a solution regarding conversion of a xfa form variable into a pdf so that the solutions components like Digital Signatures, Rights Management can be implemented in the process at required places. I have a process where a user fills up a form and is sent to different users for approval based on my Business Logic. The input is a dynamic PDF which is mapped to a xfa variable which flows in the process. Some changes are required to be made in the form at various levels. For that i have mapped the xpath's to values i want to be displayed in the form at different places. Now The problem arrives when i want to implement a rights management service at Manager's level in the process. The input which this solution component takes is a pdf but i have a xfa form variable flowing in my process.
      I have noticed tat many users in this forum are facing the same problem in one form or the other, none have got a convincing solution. So i would be very much grateful to a person who can provide step by step solution to this issue and solve the same. you would be helping many developers by providing the complete Solution.
      Thanx in advance.
        • 1. Re: Convert XFA Form Variable into a PDF Doc.
          Jasmin Charbonneau Level 4
          The easiest thing you be to
          1- Add a renderPDFForm operation to create a PDF from an XDP file.
          2- Pass the xfaForm's data (/process_data/xfaFormVar/object/data) to the data parameter of the renderPDFForm so that it merges the proper data with the XDP to re-create the PDF.
          3- Add the usage rights to the PDF.
          4- Create a new variable of type DocumentForm.
          5- Use a SetValue to put the pdf created above in the DocumentForm variable (/process_data/DocFormVar/object/@document = /process_data/@newPDF).
          6- Pass that DocumentForm variable as the input/output in the Form Data Mapping of the User step.
          Jasmin
          • 2. Re: Convert XFA Form Variable into a PDF Doc.
            vicky_rulz Level 1
            Hi Jasmin,
            Thanx for the help from your end... But needed a little more.. Can u tell me the exact details of the properties tab of the render PDF form to be entered to accomplish the first part of my sloution. I m unable to understand what exactly needs to be entered in the various fields... have attached a screen shot of my Workbench for your reference... Thanx for the help buddy !!!
            • 3. Re: Convert XFA Form Variable into a PDF Doc.
              First you want to use the renderPDFForm from the Forms category, not Sample - Forms.
              There's really only four parameters to set on the renderPDFForm:
              1- Form URL: This is the url of the form template. (ex. /Forms/myForm.xdp)
              2- inDocData: The data to merge with the form.
              3- Content Root URI: This is the where the forms are stored (ex. repository:// if they are in the Adobe repository).
              The form location should ultimately be Content Root URI + form url (repository:///Forms/myForm.xdp)
              4- Rendered Form, the resulted PDF.
              Jasmin
              • 4. Re: Convert XFA Form Variable into a PDF Doc.
                adobeMurat
                Hi Jasmin,
                I have done word by word what you said above, but still get error.
                com.adobe.livecycle.formsservice.exception.RenderFormException: xmldata: XML document structures must start and end within the same entity., cause: XML document structures must start and end within the same entity.
                at com.adobe.formServer.Controller.tweakXMLData(Controller.java:324)
                at com.adobe.formServer.Controller.render(Controller.java:115)
                at com.adobe.formServer.FormServer.renderForm(FormServer.java:191)
                at com.adobe.formServer.FormServer.renderForm(FormServer.java:257)
                at com.adobe.formServer.docservice.FormsDocService.renderForm(FormsDocService.java:483)
                at com.adobe.formServer.docservice.FormsDocService.renderForm(FormsDocService.java:421)
                at com.adobe.formServer.docservice.FormsDocService.renderPDFForm(FormsDocService.java:119)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                at java.lang.reflect.Method.invoke(Method.java:585)
                at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
                at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
                at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
                at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:342)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequired(Ej bTransactionCMTAdapterBean.java:259)
                at sun.reflect.GeneratedMethodAccessor384.invoke(Unknown Source)
                at org.jboss.invocation.Invocation.performCall(Invocation.java:345)
                at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:214)
                at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:149)
                at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:154)
                at org.jboss.webservice.server.ServiceEndpointInterceptor.invoke(ServiceEndpointInterceptor. java:54)
                at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:48)
                at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:106)
                at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:335)
                at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:166)
                at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:153)
                at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:192)
                at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:122)
                at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:624)
                at org.jboss.ejb.Container.invoke(Container.java:873)
                at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:415)
                at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:88)
                at $Proxy268.doRequired(Unknown Source)
                at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:129)
                at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
                at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
                at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
                at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:132)
                at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
                at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
                at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:118)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:91)
                at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:21 5)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
                at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
                at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:724)
                at com.adobe.workflow.engine.SynchronousBranch.handleInvokeAction(SynchronousBranch.java:466 )
                at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:863)
                at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBea n.java:2773)
                at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncInvokeProcessCommand(ProcessEngineBMT Bean.java:704)
                at sun.reflect.GeneratedMethodAccessor1158.invoke(Unknown Source)
                at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 58)
                at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:62)
                at $Proxy301.asyncInvokeProcessCommand(Unknown Source)
                at com.adobe.workflow.engine.ProcessCommandControllerBean.doOnMessage(ProcessCommandControll erBean.java:156)
                at com.adobe.workflow.engine.ProcessCommandControllerBean.onMessage(ProcessCommandController Bean.java:99)
                at sun.reflect.GeneratedMethodAccessor879.invoke(Unknown Source)
                at org.jboss.ejb.MessageDrivenContainer$ContainerInterceptor.invoke(MessageDrivenContainer.j ava:475)
                at org.jboss.ejb.plugins.MessageDrivenInstanceInterceptor.invoke(MessageDrivenInstanceInterc eptor.java:101)
                at org.jboss.ejb.plugins.RunAsSecurityInterceptor.invoke(RunAsSecurityInterceptor.java:94)
                at org.jboss.ejb.MessageDrivenContainer.internalInvoke(MessageDrivenContainer.java:389)
                at org.jboss.ejb.plugins.jms.JMSContainerInvoker.invoke(JMSContainerInvoker.java:1077)
                at org.jboss.ejb.plugins.jms.JMSContainerInvoker$MessageListenerImpl.onMessage(JMSContainerI nvoker.java:1379)
                at org.jboss.jms.asf.StdServerSession.onMessage(StdServerSession.java:256)
                at org.jboss.mq.SpyMessageConsumer.sessionConsumerProcessMessage(SpyMessageConsumer.java:904 )
                at org.jboss.mq.SpyMessageConsumer.addMessage(SpyMessageConsumer.java:160)
                at org.jboss.mq.SpySession.run(SpySession.java:333)
                at org.jboss.jms.asf.StdServerSession.run(StdServerSession.java:180)
                at EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:748)
                at java.lang.Thread.run(Thread.java:595)
                • 5. Re: Convert XFA Form Variable into a PDF Doc.
                  You get the following error in the stack trace:
                  "xmldata: XML document structures must start and end within the same entity., cause: XML document structures must start and end within the same entity."
                  That's means your variable xmldata for the data parameter doesn't contain valid xml data.
                  Jasmin
