5 Replies Latest reply on Aug 21, 2009 4:14 AM by mike@mmm
    PDF fields
    mike@mmm
      I have a product purchased form a vedor that creates PDFs.  There is an option to create fields but it's nor supported by the vendor so I can't get any information from them.  Many years ago, I created the fileds required and then tested those firlfds but I can't remeber what I used to test (ex: tab from field to field).  I need to create additional fields but don't know how to test.  All I have the is acrobat reader.  Can someone tell me the easiset way to test.
      Thanks, mike
        • 1. Re: PDF fields
          MichaelKazlow MVP & Adobe Community Professional
          You cannot add fields with Reader you need Acrobat.
          • 2. Re: PDF fields
            mike@mmm Level 1
            I know that.  I'm not trying to.  I have a product that creates PDFs with
            fields.  I want to know how to look at them and test (tab thru the fields
            and make sure the edits work).
            Mike Caplin
            3M
            Tel:    508-764-5708
            Efax: 866-755-0504
            Michael Kazlow <forums@adobe.com>
            To:
            Michael Caplin <mike.caplin@mmm.com>
            Date:
            08/20/2009 04:25 PM
            Subject:
            PDF fields
            • 3. Re: PDF fields
              ~graffiti Adobe Community Professional & MVP
              If the fields exist and work properly then you can tab through them using Reader.
              • 4. Re: PDF fields
                jcubed08
                graffiti,
                Are you stating that if a PDF was created with a product, e.g., PDF995, which can create PDFs with document properties fields, e.g., Title, Subject, Author, Keywords, and Comments, Adobe Reader should be able to tab through these document properties fields? If that is the case, does that mean Adobe Reader can tab through the fields, but does that imply that Adobe Reader can or cannot edit these same fields?
                jcubed08
                • 5. Re: PDF fields
                  mike@mmm Level 1
                  Mystery solved
                  The package that I was using to create the field was setting it as a read
                  only field and that why I couldn't tab to it or enter data into it.
                  Thank you all for your feedback.
                  Mike Caplin
                  3M
                  Tel:    508-764-5708
                  Efax: 866-755-0504
                  jcubed08 <forums@adobe.com>
                  To:
                  Date:
                  08/20/2009 07:32 PM
                  Subject:
                  PDF fields
                  graffiti,
                  jcubed08
