2 Replies Latest reply on Jun 18, 2008 7:57 AM by ccrum
    changing dataprovider in a combobox
    ccrum
      I'm trying to write an app which uses two combo boxes. If the first combo box is changed, the second combo box should be filled with a differnt set of values. I'm trying to do this by building several arrays which will correspond to a n entry in the first combo box. If one of these entries is selected, I simply want to change the dataprovider field of the second combo box. Changing the first combobox works, but instead of loading the array, it just puts one entry in which is the name of the array. Here is the code I'm using:
