5 Replies Latest reply on Oct 12, 2009 7:11 AM by 2191925#2191925
    Get an array from Java
    quebequiano
      Hi!
      I define a object in Java. Its name is User.
      public class user....{
           private name;
           private id,
      And its equivalen in action script (with the same attributes).
      My question is.... What i have to do to get an Array of User (from Java) as a Array of User in Flex.
      I've already made a the function to send the date... now i need to know how to get them in Java.
        • 1. Re: Get an array from Java
          Gregory Lafrance Level 6
          You may be able to use HTTPService or RemoteObject:
          http://giantflyingsaucer.com/blog/?p=10
          http://learn.adobe.com/wiki/display/Flex/Flex+and+Java
          If this post answers your question or helps, please mark it as such.
          • 2. Re: Get an array from Java
            Ashudeep Sidana Level 1
            You can do it by using Remote Object .
            In remoting-config.xml you need to specify the properties , which has class name (id) and the path of the class
            destination id="userInfo">
            <properties>
                 <source>user.UserInfo</source>
            </properties>
            </destination>
            This UserInfo Class will contain a method which will return the User Object .
            At flex side you need to call that by RemoteObject  as follows:
            <mx:RemoteObject
            id="remoteObject" destination="userInfo" >
                 <mx:method
            name="getUserInfo" result="getUserInfo_Result(event)" fault="onFault(event)" />
            </mx:RemoteObject>
            method would be the java class method which would return your object.
            result would be  the method where u will get the result returned from the method
            fault would be the method where u would get the error if the result is not returned.
            And the implementation of the getUserInfo_Result(event) goest like
            private
            function getUserInfo_Result(event:ResultEvent):void{
                 user:Object  = event.result  as Object;
            U can make this user object as public variable so u can use it any where in ur application.
            Hope it helps..
            • 3. Re: Get an array from Java
              quebequiano Level 1
              Yes, i know that.
              I'm already using Remote Objects. My question is about the format of the reception in Flex.
              I send the objects (as a <List>Users) from Java.
              And i tried to get them in flex:
              list:ArrayCollection=ArrayCollection(event.result).
              But I want to have a vector of User.
              How can i do it?
              • 4. Re: Get an array from Java
                I dont think there is "Vector" in Flex , u can get that in Array .
                • 5. Re: Get an array from Java
                  2191925#2191925
                  I am not even getting Object Array in Flex.
                  I am returning Object Array from java. I want to use that in Flex through Remote Object Mechanism.
                  Could you please expain me steps from staring.
                  even i tried the same syntax in flex what you suggested i.e
                  afetr this ichecked
                  if(user as object){
                  Alert.show('it is object');
                  I am not getting any Alert message.
                  Also i tried
                  it is also not working.
                  Please help me.
                  Thanks & Regards,
                  Praveen
