1 Reply Latest reply on Aug 28, 2009 9:06 PM by sri harsha namala
    using SQL view From SQL Express in Flex
    N_Oz
      Hello All ,  i am new at Flex and yet searching for a basic answere to even more basic question...
      i am currently looking for a way o extract and import SQL views from my SQL Express database ( on my local host) and present it with RIA on desktop, grpahs Charts etc.
      my question is, which way is the best to do so ?
      need i to use Coldfusion For the Data ?  and then Flex3 For the design ( i.e Graphs)?
      or maybe using another ODBC program for XML file and then Connect it as Data Resource into the flex3 project
      as you must see , i am a bit confused....
      thanks in advance
        • 1. Re: using SQL view From SQL Express in Flex
          sri harsha namala
                   If you go for AIR you can directly connect to Database and you can get the data and can be shown graphically ,
                   But if you Go for Webapplication(Flex ) then definately u should use some backend like CFC,PHP,JAVA,.Net............ in order to connect to DB and use Remote Objects/HttpService and show the Result Graphically..............
