0 Replies Latest reply on Jul 31, 2008 4:40 PM by candy_A20
    Spry Menu Customize Settings Not Applied?
    candy_A20
      I keep trying to change the color and style of my vertical spry menu, but none of these settings are being applied... What's going on ? I'm apply it to a template ...
      Code:
      @charset "UTF-8";
      /* SpryMenuBarVertical.css - version 0.6 - Spry Pre-Release 1.6.1 */
      /* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
      LAYOUT INFORMATION: describes box model, positioning, z-order
      /* The outermost container of the Menu Bar, a fixed width box with no margin or padding */
      ul.MenuBarVertical
      margin: 0;
      padding: 0;
      list-style-type: none;
      font-size: 100%;
      cursor: default;
      width: 8em;
      background-color: #006600;
      /* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
      ul.MenuBarActive
      z-index: 1000;
      font-family: Andalus, "Segoe Print", Rockwell;
      color: #009900;
      /* Menu item containers, position children relative to this container and are same fixed width as parent */
      ul.MenuBarVertical li
      margin: 0;
      padding: 0;
      font-size: 100%;
      position: relative;
      text-align: left;
      cursor: pointer;
      width: 8em;
      /* Submenus should appear slightly overlapping to the right (95%) and up (-5%) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
      ul.MenuBarVertical ul
      margin: -5% 0 0 95%;
      padding: 0;
      font-size: 100%;
      position: absolute;
      z-index: 1020;
      cursor: default;
      width: 8.2em;
      left: -1000em;
      top: 0;
      /* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
      ul.MenuBarVertical ul.MenuBarSubmenuVisible
      left: 0;
      /* Menu item containers are same fixed width as parent */
      ul.MenuBarVertical ul li
      width: 8.2em;
      DESIGN INFORMATION: describes color scheme, borders, fonts
      /* Outermost menu container has borders on all sides */
      ul.MenuBarVertical
      border: 1px solid #CCC;
      background-color: #00CC00;
      /* Submenu containers have borders on all sides */
      /* Menu items are a light gray block with padding and no text decoration */
      ul.MenuBarVertical a
      display: block;
      cursor: pointer;
      background-color: #EEE;
      padding: 0.5em 0.75em;
      color: #333;
      text-decoration: none;
      /* Menu items that have mouse over or focus have a blue background and white text */
      ul.MenuBarVertical a:hover, ul.MenuBarVertical a:focus
      background-color: #009900;
      color: #00FF00;
      /* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
      ul.MenuBarVertical a.MenuBarItemHover, ul.MenuBarVertical a.MenuBarItemSubmenuHover, ul.MenuBarVertical a.MenuBarSubmenuVisible
      background-color: #33C;
      color: #FFF;
      SUBMENU INDICATION: styles if there is a submenu under a given menu item
      /* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
      background-image: url(SpryMenuBarRight.gif);
      background-repeat: no-repeat;
      background-position: 95% 50%;
      /* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
      background-image: url(SpryMenuBarRightHover.gif);
      BROWSER HACKS: the hacks below should not be changed unless you are an expert
      /* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
      ul.MenuBarVertical iframe
      position: absolute;
      z-index: 1010;
      filter:alpha(opacity:0.1);
      border-top-style: double;
      border-right-style: double;
      border-bottom-style: double;
      border-left-style: double;
      /* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
      @media screen, projection
      ul.MenuBarVertical li.MenuBarItemIE
      display: inline;
      f\loat: left;
      background: #FFF;
