0 Replies Latest reply on Aug 4, 2008 1:41 AM by rz1
    Paragraph tags not applied correctly
    rz1
      I’m importing an FM document into RH (Technical Communication Suite). I fixed all the paragraph definitions and the mappings.
      After importing, the same paragraph tags are sometimes applied correctly and sometimes not. Most problematic are the ones that come right after a paragraph that has a bullet or number setting. It seems as though the following paragraph sometimes has a bullet or number even though you can’t see it.
      If I reapply the paragraph tag it doesn’t help, but if I apply a different one and then the original one I wanted – it works OK.
      Is there a workaround? Am I doing something wrong?
      Rakefet
