0 Replies Latest reply on Aug 20, 2009 9:19 AM by Flex harUI
    [svn:fx-trunk] 9419: 2nd attempt to check in prototypes of ControlBars in Panel and Application , Spark Containers in Halo Navigators, Halo ViewStack in Spark ButtonBar.
    Flex harUI Adobe Employee
      Revision: 9419
      Author:   aharui@adobe.com
      Date:     2009-08-20 09:19:04 -0700 (Thu, 20 Aug 2009)
      Log Message:
      2nd attempt to check in prototypes of ControlBars in Panel and Application, Spark Containers in Halo Navigators, Halo ViewStack in Spark ButtonBar.  APIs should match spec but are subject to change from PARB.  Skins are subject to tweaking after XD review
      QE Notes: The following tests will fail and need updating:
      gumbo/containers/Panel/Properties/Panel_Properties_position Panel_Properties_rotate
      apollo/spark/components/Window/properties/window_properties_titleIcon_tests titleIcon_test8
      Doc Notes: None
      Bugs: None
      Reviewer: Darrell, Glenn, Ryan
      API Change: No
      Is noteworthy for integration: No
      tests: checkintests mustella/gumbo/components/Application, gumbo/components/ButtonBar, gumbo/containers/Panel, apollo/gumbo/spark/Window, containers/ViewStack, containers/Accordion,
      states/Integration/TabNavApp, states/Reparent
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/SparkChromeWindowed ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/TabNavigator.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/ViewStack.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/NavBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexEvent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/FocusManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Application.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Panel.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/SkinnableContainer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/PanelSkin.mxml
          flex/sdk/trunk/frameworks/spark-manifest.xml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IDeferredContentOwner.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/INavigatable.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/INavigatorContent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/NavigatorChild.as
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/IDeferredContentOwner.as
