2 Replies Latest reply on Aug 21, 2009 7:54 AM by aaronb2
    How to convert CSS embedded resource backgroundImage into Bitmap?
    aaronb2 Level 1
      I am trying to convert the embedded resource backgroundImage to an bitmap so I can load it in Papervision.  The problem I am having is how do I convert it to bitmap.  I have tried different combinations to no avail.  The code I am using is below.  A side issue, I also noticed when my CSS skin does not have a backgroundImage defined I am still getting an object of class mx.skins.halo.ApplicationBackground, why is that?
      Aaron
      BTW, Here is the code
      var g:Graphics = backgroundSprite.graphics;
      var selector:CSSStyleDeclaration = StyleManager.getStyleDeclaration("Application");
      var imageClass:Class = null;
      var imageObject:Object = null;
      var image:DisplayObject = null;
      // is there an image to load?
      imageObject = selector.getStyle("backgroundImage");
      imageClass = Class(imageObject);
      // **** Here's the problem--
      // Error #1034: Type Coercion failed: cannot convert mx.skins.halo::ApplicationBackground$ to mx.skins.halo.ApplicationBackground.
      image = imageClass(imageObject) as DisplayObject;
      if (image) {
              var data:BitmapData = new BitmapData(image.width,image.height,true,0x000000);
              data.draw(image as IBitmapData);
              g.clear();
               g.beginBitmapFill(data,null,false);
               g.drawRect(0,0,viewport.width,viewport.height);
              g.endFill();
