Our master page shows in the project folder, but will not show in RBH. I've tried to resave same master page over the current one, tried to import it from outside of rbh, and tried to create a new one in RBH with the same name, all to no avail. Any suggestions?
Hi Molly
Perhaps rename the existing Master Page. For example, MasterPage2 or some variant of whatever the page name is. Then try importing it into the project.
You should also consider reporting this as a bug to Adobe. Who knows, maybe if they see enough reports of issues such as this we may see an eventual patch released for version 8.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Rick,
How'd you get so smart about RBH? So, the challenge is that I tried renaming it and the system saved the master page as part of the topic (not separate from the content), creating multiple headings on each topic (the previous master page and the new one) Does that make sense? perhaps a bug.
Someday I hope to be answering RBH questions instead of asking them.
LOL... smart about RoboHelp? Uhhhh....
It helps to have been using the product nearly every day since I discovered it back in 1992. (Both RoboHelp and Microsoft Word were at version 2 in those days. Then again, we had to compile while protecting our help from the other cavepeople with spears!)
Sorry, not really following you about RoboHelp saving the Master Page as part of a topic. It really depends on what you do with them. They can be used in two different ways:
In the second method it will appear that the Master Page has merged with the topic because the topic will contain what the Master Page contains. At least, initially. But later edits to the Master Page likely won't appear in the topic. (Whether the elements appear or not depends on where you insert them in the Master Page.
Hopefully that makes some kind of sense... Rick
We are using the master page as a header, but if i right click and select rename it adds the master page to the topic and still uses the master page...so I end up with two master page headers in every doc (the one has become a part of the topic and the one that is the master page). AHHHHH!
