9 Replies Latest reply on Aug 21, 2009 12:05 PM by bgyg
    Tree with itemRenderer can have variable row (not String data) height ?
    bgyg Level 1
      Is it possible to create a Tree that uses itemRenderer to have variable row height?
      In my itemRenderer, I create a HBox for each row.
      For some rows, I want to show VBox having multiple objects like ComboBoxes as its children.
      The VBox overlaps with the next row.
        • 1. Re: Tree with itemRenderer can have variable row (not String data) height ?
          paul.williams Level 4
          Have you tried setting the variableRowHeight property to true?
          • 2. Re: Tree with itemRenderer can have variable row (not String data) height ?
            Flex harUI Adobe Employee
            Set variableRowHeight=true
            Alex Harui
            Flex SDK Developer
            Adobe Systems Inc.
            Blog: http://blogs.adobe.com/aharui
            • 3. Re: Tree with itemRenderer can have variable row (not String data) height ?
              bgyg Level 1
              Yes, I tried.
              VariableRowHeight does not seem to be working for my case.
              I have seen it work in the case where dataprovider contains long String data and itemRenderer is Label.
              • 4. Re: Tree with itemRenderer can have variable row (not String data) height ?
                Show us the code for your renderer
                Alex Harui
                Flex SDK Developer
                Adobe Systems Inc.
                • 5. Re: Tree with itemRenderer can have variable row (not String data) height ?
                  bgyg Level 1
                  package
                  com.certusoft.ui.renderer
                  import
                  com.certusoft.domain.Parameter;
                  import
                  com.certusoft.event.AddParameterEvent;
                  import
                  com.certusoft.event.EditParameterEvent;
                  import
                  com.certusoft.event.RemoveParameterEvent;
                  import
                  com.certusoft.ui.FeatureSelectionHBox;
                  import
                  com.certusoft.ui.ParameterSelectionHBox;
                  import
                  com.certusoft.util.Properties;
                  import
                  flash.events.ContextMenuEvent;
                  import
                  flash.ui.ContextMenu;
                  import
                  flash.ui.ContextMenuItem;
                  import
                  mx.controls.treeClasses.TreeItemRenderer;
                  import
                  mx.controls.treeClasses.TreeListData;
                  import
                  mx.core.IFactory;
                  public class FeatureTreeItemRenderer extends TreeItemRenderer implements
                  IFactory
                  private var
                  _parameterSelectionHBox:ParameterSelectionHBox;
                  private var
                  _featureSelectionHBox:FeatureSelectionHBox;
                  private var
                  _featureSelectionHBoxLeaf:FeatureSelectionHBox;
                  private var _dataChanged:Boolean = false
                  private var add:ContextMenuItem = new ContextMenuItem("Add at End"
                  private var addBefore:ContextMenuItem = new ContextMenuItem("Add Before"
                  private var addAfter:ContextMenuItem = new ContextMenuItem("Add After"
                  private var remove:ContextMenuItem = new ContextMenuItem("Remove"
                  private var edit:ContextMenuItem = new ContextMenuItem("Edit"
                  public function
                  newInstance():*
                  return new
                  FeatureTreeItemRenderer();
                  public function
                  super
                  // Context menu
                  var contextMenu:ContextMenu = new
                  ContextMenu();
                  var
                  menuItems:Array = [];
                  add.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, addParamHandler);
                  menuItems.push(add);
                  addBefore.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, addParamHandler);
                  menuItems.push(addBefore);
                  addAfter.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, addParamHandler);
                  menuItems.push(addAfter);
                  remove.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, removeParamHandler);
                  menuItems.push(remove);
                  edit.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, editParamHandler);
                  menuItems.push(edit);
                  contextMenu.customItems = menuItems;
                  contextMenu.hideBuiltInItems();
                  this
                  .contextMenu = contextMenu;
                  private function editParamHandler(event:ContextMenuEvent):void
                  var
                  dataObj:Object = data;
                  if (data instanceof
                  Parameter)
                  var dataParam:Parameter = data as
                  Parameter;
                  dispatchEvent(
                  new EditParameterEvent(dataParam, true
                  private function removeParamHandler(event:ContextMenuEvent):void
                  var
                  if (data instanceof
                  Parameter)
                  Parameter;
                  dispatchEvent(
                  new RemoveParameterEvent(dataParam, true
                  private function addParamHandler(event:ContextMenuEvent):void
                  var
                  if (data instanceof
                  Parameter)
                  Parameter;
                  var menuItem:ContextMenuItem = event.target as
                  ContextMenuItem;
                  dispatchEvent(
                  new AddParameterEvent(dataParam, menuItem.caption, true
                  private function
                  hasChildren():Boolean
                  return (TreeListData(super.listData).item as
                  Parameter).hasChildren();
                  override public function set data(value:Object):
                  void
                  // setting the data property of the parent will also trigger:
                  // call to invalidateProperties()
                  // dispatchEvent(new FlexEvent(FlexEvent.DATA_CHANGE));
                  if
                  (data != value)
                  _dataChanged =
                  true
                  super
                  .data = value;
                  if
                  (hasChildren())
                  var isSelectableByName:Boolean = Properties.getBindVal(data as Parameter, Properties.isSelectableByName) as
                  Boolean;
                  if
                  (isSelectableByName)
                  styleName =
                  "headerItem"
                  _parameterSelectionHBox.visible =
                  false
                  _featureSelectionHBox.visible =
                  true
                  _featureSelectionHBoxLeaf.visible =
                  false
                  addBefore.enabled =
                  true
                  addAfter.enabled =
                  true
                  add.enabled =
                  true
                  remove.enabled =
                  true
                  edit.enabled =
                  true
                  else
                  styleName =
                  "headerItem"
                  false
                  false
                  false
                  addBefore.enabled =
                  false
                  addAfter.enabled =
                  false
                  add.enabled =
                  false
                  remove.enabled =
                  false
                  edit.enabled =
                  false
                  else
                  Boolean;
                  if
                  styleName =
                  "parameterItem"
                  false
                  false
                  true
                  addBefore.enabled =
                  true
                  addAfter.enabled =
                  true
                  add.enabled =
                  true
                  remove.enabled =
                  true
                  edit.enabled =
                  true
                  else
                  styleName =
                  "parameterItem"
                  true
                  false
                  false
                  addBefore.enabled =
                  false
                  addAfter.enabled =
                  false
                  add.enabled =
                  false
                  remove.enabled =
                  false
                  edit.enabled =
                  false
                  else
                  _dataChanged =
                  false
                  * Create child objects of the component.
                  * From within an override of the createChildren() method, you call the addChild() method to add each child object.
                  * You do not call this method directly.
                  * Flex calls the createChildren() method in response to the call to the addChild() method to add the component to its parent.
                  override protected function createChildren():
                  void
                  super
                  .createChildren();
                  _parameterSelectionHBox =
                  new
                  ParameterSelectionHBox()
                  addChild(_parameterSelectionHBox);
                  _featureSelectionHBox =
                  new FeatureSelectionHBox(false
                  addChild(_featureSelectionHBox);
                  _featureSelectionHBoxLeaf =
                  new FeatureSelectionHBox(true
                  addChild(_featureSelectionHBoxLeaf);
                  * Processes the properties set on the component.
                  * To coordinate the modifications of multiple properties so that the modifications occur synchronously.
                  * The commitProperties() method executes during the next render event after a call to the invalidateProperties() method
                  * Calls to the commitProperties() method occur before calls to the measure() method.
                  * This lets you set property values that the measure() method might use.
                  override protected function commitProperties():
                  void
                  super
                  .commitProperties();
                  if
                  (_dataChanged)
                  Boolean;
                  if
                  _featureSelectionHBox.parameter = data
                  as
                  Parameter;
                  _featureSelectionHBoxLeaf.parameter = data
                  as
                  Parameter;
                  else
                  _parameterSelectionHBox.parameter = data
                  as
                  Parameter;
                  * The measure() method sets the default component size, in pixels, and optionally sets the component's default minimum size.
                  * When you set a specific height and width of a component, Flex does not call the measure() method, even if you explicitly
                  * call the invalidateSize() method. That is, Flex calls the measure() method only if the explicitWidth property or the
                  * explicitHeight property of the component is NaN.
                  override protected function measure():
                  void
                  super
                  .measure();
                  // var lineMetrics:TextLineMetrics = measureText("Measure Me");
                  // measuredWidth=100;
                  // measuredMinWidth=50;
                  // measuredHeight=50;
                  // measuredMinHeight=25;
                  * Draws the object and/or sizes and positions its children.
                  * If the component has no children, this method is where you would do programmatic drawing.
                  * If the component has children, this method is where you would call the move() and setActualSize() methods on its children.
                  * @param unscaledWidth Specifies the width of the component, in pixels,
                  * in the component's coordinates, regardless of the value of the
                  * <code>scaleX</code> property of the component. This is the width of
                  * the component as determined by its parent container.
                  * @param unscaledHeight Specifies the height of the component, in pixels,
                  * <code>scaleY</code> property of the component. This is the height of
                  override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):
                  void
                  super
                  .updateDisplayList(unscaledWidth, unscaledHeight);
                  if (super
                  .data)
                  if
                  (hasChildren())
                  Boolean;
                  if
                  _featureSelectionHBox.move(TreeListData(
                  super
                  .listData).indent + 150, 0);
                  _featureSelectionHBox.setActualSize(unscaledWidth, unscaledHeight);
                  else
                  _parameterSelectionHBox.move(TreeListData(
                  super
                  .listData).indent, 0);
                  _parameterSelectionHBox.setActualSize(unscaledWidth, unscaledHeight);
                  // var children:int = (TreeListData(super.listData).item as Parameter).children.length;
                  // super.label.text = TreeListData(super.listData).label + " (" + children + ")";
                  else
                  Boolean;
                  super.label.text = ""
                  if
                  (!isSelectableByName)
                  super
                  else
                  _featureSelectionHBoxLeaf.move(TreeListData(
                  super
                  • 6. Re: Tree with itemRenderer can have variable row (not String data) height ?
                    bgyg Level 1
                    In the code, each row of tree shows one HBox. I want to be able to change dynamically the contents of featureSelectionHBox -- which is currently HBox containing checkbox and combobox and label -- so that it becomes a VBox containg multiple HBoxes.
                    • 7. Re: Tree with itemRenderer can have variable row (not String data) height ?
                      bgyg Level 1
                      And here is my Tree.
                      _tree =
                      new
                      Tree();
                      // _tree.percentHeight = 100;
                      _tree.percentWidth = 100;
                      // _tree.rowHeight = 26;
                      _tree.setStyle(
                      "left"
                      , 2);
                      _tree.setStyle(
                      "right"
                      , 2);
                      _tree.setStyle(
                      "top"
                      , 2);
                      _tree.setStyle(
                      "bottom"
                      , 2);
                      _tree.selectable =
                      true
                      _tree.labelFunction = treeLabelFunction;
                      _tree.styleName =
                      "featureTree"
                      _product = _treeDao.treeStructure;
                      _tree.dataProvider = _product;
                      _tree.itemRenderer = _renderer;
                      _tree.variableRowHeight =
                      true
                      _vBox.addChild(_tree);
                      this
                      .addChild(_vBox);
                      • 8. Re: Tree with itemRenderer can have variable row (not String data) height ?
                        You will need to modify the measure() method to properly measure your component.
                        Alex Harui
                        Flex SDK Developer
                        Adobe Systems Inc.
