5 Replies Latest reply on Aug 20, 2009 5:20 PM by Gregory Lafrance
    new to value objects - need help
    wolfman33
      Hi guys,
      I'm just starting out with flex builder, and i sorta grasp the concept of MVC and using value objects and custom event, and components.
      However, based on the all the examples floating around there on the web, I still cannot apply these to my own project. Any help would be appreciated.
      Here is what I need to do:
      I have the main application file that has a datagrid with a data provider  that's an array collection. (lets say with 2 fields: name and address)
      I have a custom component that's a panel with 2 labels inside. (name and address)
      I need to simply pass the currently selected record's name and address to the custom component's labels.
      And I need to this with value objects and event objects.
      (i already know how to do this with binding properties, but I hear that's bad practice)
      A step by step description would be very helpful.
      Thanks in advance.
        • 1. Re: new to value objects - need help
          Gregory Lafrance Level 6
          Here is my Flex Cookbook post on using custom events to pass data around:
          http://www.adobe.com/cfusion/communityengine/index.cfm?event=showdetails&postId=11246&prod uctId=2&loc=en_US
          If this post answered your question or helped, please mark it as such.
          • 2. Re: new to value objects - need help
            wolfman33 Level 1
            Hi Greg,
            I've seen your tutorial before, and it's very impressive and helpful.
            But I need something simpler, based on the example I provided, so that I don't have to do too much reverse engeneering.
            • 3. Re: new to value objects - need help
              http://livedocs.adobe.com/flex/3/html/help.html?content=createevents_3.html
              -------------- MyEvent.as ---------------
              package
                import flash.events.Event;
                [Bindable]
                public class MyEvent extends Event{
                  public var name:String;
                  public var address:String;
                  public static const DATA_TRANSFER:String = "data_transfer";
                  public function MyEvent(name:String, address:String) {
                    super(MyEvent.DATA_TRANSFER, true);
                    this.name = name;
                    this.address = address;
                  override public function clone():Event {
                    return new MyEvent(name, address);
              -------------- MyPanel.mxml ---------------
              <mx:Panel xmlns:mx="http://www.adobe.com/2006/mxml"
                width="400" height="300" creationComplete="init();">
                <mx:Script>
                  <![CDATA[
                    import MyEvent;
                    private function init():void{
                      systemManager.addEventListener(MyEvent.DATA_TRANSFER, handleDataTransfer);
                    private function handleDataTransfer(evt:MyEvent):void{
                      this.lblName.text = evt.name;
                      this.lblAddress.text = evt.address;
                </mx:Script>
                <mx:HBox>
                  <mx:Label text="Name: "/>
                  <mx:Label id="lblName"/>
                </mx:HBox>
                <mx:HBox>
                  <mx:Label text="Address: "/>
                  <mx:Label id="lblAddress"/>
                </mx:HBox>
              </mx:Panel>
              -------------- MainApp.mxml ---------------
              <?xml version="1.0"?>
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                xmlns:comp="*">
                <mx:Script>
                  <![CDATA[
                    import mx.collections.ArrayCollection;
                    import MyEvent;
                    [Bindable] private var aCollection:ArrayCollection = new ArrayCollection([
                      {name: "name1", address: "address1"},
                      {name: "name2", address: "address2"},
                      {name: "name3", address: "address3"}
                    private function changeHandler(evt:Event):void{
                      var myEVT:MyEvent = new MyEvent(evt.currentTarget.selectedItem.name, evt.currentTarget.selectedItem.address);
                      this.dispatchEvent(myEVT);
                </mx:Script>
                <mx:DataGrid dataProvider="{aCollection}" change="changeHandler(event)">
                  <mx:columns>
                    <mx:DataGridColumn dataField="name" headerText="Name" />
                    <mx:DataGridColumn dataField="address" headerText="Address" />
                  </mx:columns>
                </mx:DataGrid>
                <comp:MyPanel/>
              </mx:Application>
              • 4. Re: new to value objects - need help
                wolfman33 Level 1
                Thanks for that. It works beautifuly.
                Is there a way to do this using a value object? or a model object?
                You know, instead of passing each value seperately using the event, you can just pass the array collection into a value object, then make the value object accessable through the custom component?
                • 5. Re: new to value objects - need help
                  I'll let you add code to process the entire ArrayCollection now
                  package
                    [Bindable]
                    public class ValueObject extends Object{
                      public var dataObject:Object;
                      public function ValueObject(dataObject:Object){
                        super();
                        this.dataObject = dataObject;
                  package
                    import ValueObject;
                    [Bindable]
                      public var vo:ValueObject;
                      public function MyEvent(vo:ValueObject) {
                        this.vo = vo;
                        return new MyEvent(vo);
                    <mx:Script>
                      <![CDATA[
                        import MyEvent;
                          this.lblName.text = ArrayCollection(evt.vo.dataObject).getItemAt(0).name;
                          this.lblAddress.text = ArrayCollection(evt.vo.dataObject).getItemAt(0).address;
                    </mx:Script>
                    <mx:HBox>
                    </mx:HBox>
                    <mx:HBox>
                    </mx:HBox>
                  </mx:Panel>
                    xmlns:comp="*">
                    <mx:Script>
                      <![CDATA[
                        import MyEvent;
                          var myEVT:MyEvent = new MyEvent(new ValueObject(aCollection));
                    </mx:Script>
                      <mx:columns>
                      </mx:columns>
                    </mx:DataGrid>
                    <comp:MyPanel/>
                  </mx:Application>
