0 Replies Latest reply on Aug 20, 2009 4:54 PM by CoreyRLucier
    [svn:fx-trunk] 9433: Code complete for runtime design layers.
    CoreyRLucier Adobe Employee
      Revision: 9433
      Author:   clucier@adobe.com
      Date:     2009-08-20 16:54:36 -0700 (Thu, 20 Aug 2009)
      Log Message:
      Code complete for runtime design layers.  Incorporated PARB renames and refactoring.  Finished off all compiler optimizations that were spec'd.  Some minor bug fixes.
      QE notes: Candidate checkin for code complete. You are welcome to write test plan against the current API.
      Doc notes:  DesignLayer docs should be scrubbed.
      Bugs:  N/A
      Reviewer: Peter (compiler), Chet (renames), Paul (will review MXMLDocument post PTO).
      Tests run: Checkin, added new basic test.
      Is noteworthy for integration: Yes.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/DesignLayer.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElement.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/TextGraphicE lement.as
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests-config.xml
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests.mxml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      Added Paths:
          flex/sdk/trunk/frameworks/tests/basicTests/spark/scripts/DesignLayerTestScript.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/spark/views/DesignLayerTests.mxml
