5 Replies Latest reply on Aug 23, 2009 11:55 PM by Willam van Weelden
    WYSIWYG editing corrupts the footer HTML
    yenelli Level 1
      Previous discussion re "ugly footer" suggests an HTML annoyance/pitfall when editing in the WYSIWYG view.
      Willam suggested setting the {P class footer}--which is tweaking HTML OUTSIDE the master page.
      Does anyone have recommendations about use the class settings rather than work through the GUI list of paragraph/character styles?
      I've been splitting long topics in two by duplicating them and then deleting parts to remove replication.
      Can someone provide insight/advice as to why the HTML  (<?rh-placeholder type="footer" ?>) stuff got mangled when editing topics in WYSIWYG?
      Is it unsafe to cut and paste in WYSIWYG?
      RobhHelp HTML project using RH8, publishing WebHelp (primary layout)
        • 1. Re: WYSIWYG editing corrupts the footer HTML
          RoboWizard Level 4
          Hi there
          The code you are citing is something that would be managed by RoboHelp. So editing using the WYSIWYG should be totally safe.
          It's anyone's guess as to why or how it got mangled on you.
          Copying and pasting in WYSIWYG is usually totally safe. The only possible issue with editing in WYSIWYG view is if you attempt to modify a Header or Footer. But even if you did, RoboHelp normally advises that you are editing an element that may affect several other topics. It then normally offers an option to update for all topics or to disassociate from the Template / Master Page and keep the changes only on this topic.
          Cheers.. Rick
          Helpful and Handy Links
          RoboHelp Wish Form/Bug Reporting Form
          Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
          Adobe Certified RoboHelp HTML Training
          SorcerStone Blog
          RoboHelp eBooks
          • 2. Re: WYSIWYG editing corrupts the footer HTML
            yenelli Level 1
            Thanks Rick.
            One would think, then, that in order to fix the footer problem (the missing lines of stuff), cited one should edit the Master page and reapply it to the topics. I'm trying to trace possible causes. In HTML view, I see that the "ugly black line" definition (snippet below) got into the  of some topics--and this is the cause of the "ugly" footer in the PUBLISHED topic. In Design view (WYSIWYG) the source file shows the copyright footer. . . .   /<![CDATA[/
            body {
                 border-bottom-style: Solid;
                 border-bottom-width: 4px;
            /]]>/</style>
            </head>
            I DO know that I have a solid 4px line defined for H2 (the topic title), but it is in a lovely blue hue. How the H2 bottom border got into the page definition is the mystery.
            • 3. Re: WYSIWYG editing corrupts the footer HTML
              Willam van Weelden Adobe Community Professional & MVP
              What do you mean exactly by: "Does anyone have recommendations about use the class settings rather than work through the GUI list of paragraph/character styles?"
              What I've seen in your previous post, suggests that you use the paragraph class Footer for your copyright notice. I think it is allways better, for all styling, to select a class from the drop down list.
              If you always select Footer for you footer text, you can edit the style of all your footers by simply editing your style sheet. You can ofcourse style any element by using the different styling buttons from RoboHelp. Whenever you need to change those styles, you have to manually edit the paragraphs. This will not be a problem for your footer, since you only style it from a template of master page. However, say that you make all names of screen blue and bold and suddenly you want them to be green and italic. If you styled the screen names using a class, you can change all screen names from your style sheet. If you styled using the styling buttons, you will either have to use a find and replace option, or you must change every sreen name by hand.
              Greet,
              Willam
              • 4. Re: WYSIWYG editing corrupts the footer HTML
                yenelli Level 1
                Hi Willam,
                When you use the term "class settings"
                I interpreted that as something special RoboHelp java script that use { class  ; and <?rh- type HTML.
                Now I see by your Capture1.jpg that you are referring to "style"  (the word I'm familiar with). The tooltip I see for that control is "Apply Style"
                Thanks. I agree completely with the rest of what you wrote.
                • 5. Re: WYSIWYG editing corrupts the footer HTML
                  Sorry that I wasn't clear enough earlier. You do apply a style, but you should know that a class is not a style.
                  Say that you have three different kind of paragraphs, footer, header and body-text. You select a style from the style menu, but for HTML, a paragraph is just a paragraph, there's no difference between the three. The class is style class from your style sheet that you use to control how the paragraph is displayed.
                  Greets,
                  Willam
