3 Replies Latest reply on Aug 22, 2009 1:53 PM by ShardulSingh
    Re:Changing datagrid row color flex2
    Venkat,Flex Developer Level 1
      I am migating my application from Flex1.5  to Flex 2 i used dg.setpropertiesAt(i, "backgroundColor:0xFF000") to change datagrid particular background color but this one is not working in Flex2 can i have the alternative for this
        • 1. Re:Changing datagrid row color flex2
          ShardulSingh Level 3
          Pls try the code below.
          MainApplication
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
          layout="vertical">
          <mx:Script>
          <![CDATA[
          import mx.collections.ArrayCollection;
          import mx.events.ListEvent;
          [Bindable]
          private var dgArrayCollection:ArrayCollection=
          new ArrayCollection([
          {color:'0xFF0000', names:'John'},
          {color:'0x00FF00', names:'Alex'},
          {color:'0x0000FF', names:'Peter'},
          {color:'0xFF0000', names:'Sam'},
          {color:'0x00FF00', names:'Alis'},
          {color:'0x0000FF', names:'Robin'},
          {color:'0xFF0000', names:'Mark'},
          {color:'0x00FF00', names:'Steave'},
          {color:'0x0000FF', names:'Fill'},
          {color:'0xFF0000', names:'Abraham'},
          {color:'0x00FF00', names:'Hennery'},
          {color:'0x0000FF', names:'Luis'},
          {color:'0xFF0000', names:'Herry'},
          {color:'0x00FF00', names:'Markus'},
          {color:'0x0000FF', names:'Flip'},
          {color:'0xFF0000', names:'John_1'},
          {color:'0x00FF00', names:'Alex_1'},
          {color:'0x0000FF', names:'Peter_1'},
          {color:'0xFF0000', names:'Sam_1'},
          {color:'0x00FF00', names:'Alis_1'},
          {color:'0x0000FF', names:'Robin_1'},
          {color:'0xFF0000', names:'Mark_1'},
          {color:'0x00FF00', names:'Steave_1'},
          {color:'0x0000FF', names:'Fill_1'},
          {color:'0xFF0000', names:'Abraham_1'},
          {color:'0x00FF00', names:'Hennery_1'},
          {color:'0x0000FF', names:'Luis_1'},
          {color:'0xFF0000', names:'Herry_1'},
          {color:'0x00FF00', names:'Markus_1'},
          {color:'0x0000FF', names:'Flip_2'},
          {color:'0xFF0000', names:'John_2'},
          {color:'0x00FF00', names:'Alex_2'}
          private function onItemClick(event : ListEvent):void
          var dataObj : Object = event.itemRenderer.data;
          dataObj.color = "0xFF00FF";
          event.itemRenderer.data = dataObj;
          </mx:Script>
          <mx:VBox width="300" height="100%"
          horizontalAlign="center"
          verticalAlign="middle">
          <mx:DataGrid id="dg" width="50%"
          height="100%"
          borderStyle="none"
          itemRenderer="DataGridItemRenderer"
          dataProvider="{dgArrayCollection}"
          itemClick="onItemClick(event)">
          <mx:columns>
          <mx:DataGridColumn dataField="names" headerText="Names"/>
          </mx:columns>
          </mx:DataGrid>
          </mx:VBox>
          </mx:Application>
          <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml"
          width="100" height="30" horizontalGap="5"
          backgroundColor="{data.color}">
          <mx:Script>
          <![CDATA[
          override public function set data(value:Object):void
          super.data = value;
          </mx:Script>
          <mx:Label width="75" height="30"
          text="{data.names}"/>
          </mx:HBox>
          Pls let me know if you have any issue,or this post helps you.
          with Regards
          Shardul Singh Bartwal
          • 2. Re:Changing datagrid row color flex2
            HI shardul
            Thanks for your replay this one is useful when there is a event occurs but for me a particular row color should be changed when the data grid is loaded
            public function changecolor():void
                    for (var i:Number=0; i<ArrayCollection(popupdg.dataProvider).length; i++){
                    popupdg.selectedIndex = i;
                         if(popupdg.selectedItem.cancelled==true)
                       popupdg.setpropertiesAt(i, "backgroundColor:0xFF000");
                    popupdg.selectedIndex = -1;
            This is my code in flex1.5
            • 3. Re:Changing datagrid row color flex2
              Ok.....then u dont require to use the color change on the click of row.But I am already changing the color of each row on the load of datagrid.
              I am using three diffrent colors, u can use one or any number as u wish.
              Shardul singh Bartwal
