0 Replies Latest reply on Aug 22, 2009 5:25 AM by VinodhaPalanisamy
    How to add child node and child items into a parent node in tree in Flex?
    VinodhaPalanisamy
      Hi all ,
                 This is the code to add child node and child items into a parent node in tree in flex. With out use CustomClass for descriptor in Tree.
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()"
      <mx:Script>
      <![CDATA[
      import
      mx.events.ListEvent;
      import
      mx.controls.Alert;
      import
      mx.collections.IViewCursor;
      import
      mx.controls.treeClasses.ITreeDataDescriptor;
      import
      mx.controls.treeClasses.TreeListData;
      import
      mx.controls.treeClasses.TreeItemRenderer;
      import
      mx.events.TreeEvent;
      import
      mx.collections.ArrayCollection;
      var locationAC:ArrayCollection = new
      ArrayCollection();
      public var treeLocationObj:Object = new
      Object();
      public var groupAC:ArrayCollection = new
      ArrayCollection();
      public var resourceAC:ArrayCollection = new
      ArrayCollection();
      // To load parent nodes like 'Locations', when we run project
      public function init():
      void
      var locTreeObj1:Object = {label:"Jayanagar 7th Block", id:"1", children:new
      ArrayCollection()};
      locationAC.addItem(locTreeObj1);
      var locTreeObj2:Object = {label:"BTM Layout", id:"2", children:new
      ArrayCollection()};
      locationAC.addItem(locTreeObj2);
      var locTreeObj3:Object = {label:"Chennimalai", id:"3", children:new
      ArrayCollection()};
      locationAC.addItem(locTreeObj3);
      //Get node object as TreeEvent
      private function addChildren(event:TreeEvent):
      void
      treeLocationObj = event.item;
      getLocationId(event.item[
      "id"
      public function getLocationId(id:String):
      void
      //To get depth of a particular node (treeLocationObj)
      var
      d:int = TreeListData(TreeItemRenderer(tree.itemToItemRenderer(treeLocationObj)).listData).depth;
      var
      str:String = TreeListData(TreeItemRenderer(tree.itemToItemRenderer(treeLocationObj)).listData).label;
      if
      (d == 1)
      //Construct arraycollection
      groupAC =
      new
      ArrayCollection();
      var groupObj1:Object = {label:"IdeasGroup", id:"1", children:new
      ArrayCollection()};
      groupAC.addItem(groupObj1);
      var groupObj2:Object = {label:"ItrxGroup", id:"2", children:new
      ArrayCollection()};
      groupAC.addItem(groupObj2);
      loadChildGroup();
      if
      (d == 2)
      getGroupId(id);
      private function loadChildGroup():
      void
      removeChildItems(treeLocationObj);
      for (var
      i:int=0; i < groupAC.length; i++)
      tree.dataDescriptor.addChildAt(treeLocationObj, groupAC.getItemAt(i), 0, locationAC);
      public function getGroupId(id:String):
      void
      resourceAC =
      new
      ArrayCollection();
      var resourceObj1:Object = {label:"Vinodha", id:"1"
      resourceAC.addItem(resourceObj1);
      var resourceObj2:Object = {label:"Bhuvanesh", id:"2"
      resourceAC.addItem(resourceObj2);
      addChildItem();
      private function removeChildItems(parentNode:Object):
      void
      var
      descriptor:ITreeDataDescriptor = tree.dataDescriptor;
      var
      childItems:Object;
      var
      cursor:IViewCursor;
      var
      hasChild:Boolean = descriptor.hasChildren(parentNode, locationAC);
      if
      (hasChild)
      childItems = descriptor.getChildren(parentNode);
      if
      (childItems)
      cursor = childItems.createCursor();
      while
      (!cursor.afterLast)
      cursor.remove();
      private function addChildItem():
      void
      for (var
      i:int = 0; i< resourceAC.length; i++)
      tree.dataDescriptor.addChildAt(treeLocationObj, resourceAC.getItemAt(i), 0, locationAC);
      private function removeItems(event:TreeEvent):
      void
      //var ind:int = TreeListData(TreeItemRenderer(tree.itemToItemRenderer(event.item)).listData).rowIndex;
      var
      var
      childItems:Object;
      var
      cursor:IViewCursor;
      //var childItem:Object;
      childItems = descriptor.getChildren(event.item);
      if
      (childItems)
      while
      (!cursor.afterLast)
      //childItem = cursor.current;
      cursor.remove();
      public function getResourceID(event:ListEvent):
      void
      Alert.show(
      "ID:"+ event.currentTarget.selectedItem["id"
      Alert.show(
      "label:"+event.currentTarget.selectedItem["label"
      </mx:Script>
      <mx:Tree x="71" y="45" id="tree" dataProvider="{locationAC}
      " itemOpen="addChildren(event)"
      itemClose="removeItems(event)" itemClick="getResourceID(event)"
      ></mx:Tree>
      </mx:Application>
