0 Replies Latest reply on Aug 22, 2009 5:40 AM by VinodhaPalanisamy
    How to add child node and child items into a parent node in tree in Flex? (CustomClass)
    VinodhaPalanisamy
      Hi all ,
              Here, i have given 2 files to add child node and child items into a parent node in tree in flex. Here, i have used a custom class. This class, to
      getChildren(),
      isBranch(),
      hasChildren(),
      getData(),
      addChildAt(),
      removeChildAt().
      1.MyCustomTreeDataDescriptor.as
      2.TreeAddChild.mxml
      package
      // myComponents/MyCustomTreeDataDescriptor.as
      import
      mx.collections.ArrayCollection;
      import
      mx.collections.CursorBookmark;
      import
      mx.collections.ICollectionView;
      import
      mx.collections.IViewCursor;
      import
      mx.controls.Alert;
      import
      mx.controls.treeClasses.*;
      import
      mx.events.CollectionEvent;
      import
      mx.events.CollectionEventKind;
      public
      class MyCustomTreeDataDescriptor implements ITreeDataDescriptor
      // The getChildren method requires the node to be an Object
      // with a children field.
      // If the field contains an ArrayCollection, it returns the field
      // Otherwise, it wraps the field in an ArrayCollection.
      public function getChildren(node:Object,
      model:Object=
      null):ICollectionView
      try
      if (node is Object) {
      if(node.children is ArrayCollection){
      return node.children;
      else{
      return new ArrayCollection(node.children);
      catch (e:Error) {
      trace("[Descriptor] exception checking for getChildren");
      return null;
      // The isBranch method simply returns true if the node is an
      // Object with a children field.
      // It does not support empty branches, but does support null children
      // fields.
      public function isBranch(node:Object, model:Object=null):Boolean {
      try {
      if (node.children != null) {
      return true;
      catch (e:Error) {
      trace("[Descriptor] exception checking for isBranch");
      return false;
      // The hasChildren method Returns true if the
      // node actually has children.
      public function hasChildren(node:Object, model:Object=null):Boolean {
      if (node == null)
      return false;
      var children:ICollectionView = getChildren(node, model);
      try {
      if (children.length > 0)
      return true;
      catch (e:Error) {
      return false;
      // The getData method simply returns the node as an Object.
      public function getData(node:Object, model:Object=null):Object {
      try {
      return node;
      catch (e:Error) {
      return null;
      // The addChildAt method does the following:
      // If the parent parameter is null or undefined, inserts
      // the child parameter as the first child of the model parameter.
      // If the parent parameter is an Object and has a children field,
      // adds the child parameter to it at the index parameter location.
      // It does not add a child to a terminal node if it does not have
      // a children field.
      public function addChildAt(parent:Object, child:Object, index:int,
      model:Object=
      null):Boolean {
      var event:CollectionEvent = new CollectionEvent(CollectionEvent.COLLECTION_CHANGE);
      event.kind = CollectionEventKind.ADD;
      event.items = [child];
      event.location = index;
      if (!parent) {
      var iterator:IViewCursor = model.createCursor();
      iterator.seek(CursorBookmark.FIRST, index);
      iterator.insert(child);
      else if (parent is Object) {
      if (parent.children != null) {
      if(parent.children is ArrayCollection) {
      parent.children.addItemAt(child, index);
      if (model){
      model.dispatchEvent(event);
      model.itemUpdated(parent);
      return true;
      else {
      parent.children.splice(index, 0, child);
      if (model)
      return true;
      return false;
      // The removeChildAt method does the following:
      // removes the child at the specified index
      // in the model.
      // removes the child at the index parameter location in the parent.
      public function removeChildAt(parent:Object, child:Object, index:int, model:Object=null):Boolean
      event.kind = CollectionEventKind.REMOVE;
      //handle top level where there is no parent
      if (!parent)
      Alert.show(
      "not sparent");
      iterator.remove();
      if (model)
      return true;
      Alert.show(
      "parent");
      if (parent.children != undefined)
      parent.children.splice(index, 1);
      if (model)
      return true;
      return false;
      2.TreeAddChild.mxml
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init()"
      <mx:Script>
      <![CDATA[
      import
      mx.events.ListEvent;
      import
      mx.controls.Alert;
      import
      import
      mx.controls.treeClasses.ITreeDataDescriptor;
      import
      mx.controls.treeClasses.TreeListData;
      import
      mx.controls.treeClasses.TreeItemRenderer;
      import
      mx.events.TreeEvent;
      import
      var locationAC:ArrayCollection = new
      ArrayCollection();
      public var treeLocationObj:Object = new
      Object();
      public var groupAC:ArrayCollection = new
      ArrayCollection();
      public var resourceAC:ArrayCollection = new
      ArrayCollection();
      // To load parent nodes like 'Locations', when we run project
      public function init():
      void
      var locTreeObj1:Object = {label:"Jayanagar 7th Block", id:"1", children:new
      ArrayCollection()};
      locationAC.addItem(locTreeObj1);
      var locTreeObj2:Object = {label:"BTM Layout", id:"2", children:new
      ArrayCollection()};
      locationAC.addItem(locTreeObj2);
      var locTreeObj3:Object = {label:"Chennimalai", id:"3", children:new
      ArrayCollection()};
      locationAC.addItem(locTreeObj3);
      //Get node object as TreeEvent
      private function addChildren(event:TreeEvent):
      void
      treeLocationObj = event.item;
      getLocationId(event.item[
      "id"
      public function getLocationId(id:String):
      void
      //To get depth of a particular node (treeLocationObj)
      var
      d:int = TreeListData(TreeItemRenderer(tree.itemToItemRenderer(treeLocationObj)).listData).depth;
      var
      str:String = TreeListData(TreeItemRenderer(tree.itemToItemRenderer(treeLocationObj)).listData).label;
      if
      (d == 1)
      //Construct arraycollection
      groupAC =
      new
      ArrayCollection();
      var groupObj1:Object = {label:"IdeasGroup", id:"1", children:new
      ArrayCollection()};
      groupAC.addItem(groupObj1);
      var groupObj2:Object = {label:"ItrxGroup", id:"2", children:new
      ArrayCollection()};
      groupAC.addItem(groupObj2);
      loadChildGroup();
      if
      (d == 2)
      getGroupId(id);
      private function loadChildGroup():
      void
      removeChildItems(treeLocationObj);
      for (var
      i:int=0; i < groupAC.length; i++)
      tree.dataDescriptor.addChildAt(treeLocationObj, groupAC.getItemAt(i), 0, locationAC);
      public function getGroupId(id:String):
      void
      resourceAC =
      new
      ArrayCollection();
      var resourceObj1:Object = {label:"Vinodha", id:"1"
      resourceAC.addItem(resourceObj1);
      var resourceObj2:Object = {label:"Bhuvanesh", id:"2"
      resourceAC.addItem(resourceObj2);
      addChildItem();
      private function removeChildItems(parentNode:Object):
      void
      var
      descriptor:ITreeDataDescriptor = tree.dataDescriptor;
      var
      childItems:Object;
      var
      cursor:IViewCursor;
      var
      hasChild:Boolean = descriptor.hasChildren(parentNode, locationAC);
      if
      (hasChild)
      childItems = descriptor.getChildren(parentNode);
      if
      (childItems)
      cursor = childItems.createCursor();
      while
      (!cursor.afterLast)
      cursor.remove();
      private function addChildItem():
      void
      for (var
      i:int = 0; i< resourceAC.length; i++)
      tree.dataDescriptor.addChildAt(treeLocationObj, resourceAC.getItemAt(i), 0, locationAC);
      private function removeItems(event:TreeEvent):
      void
      //var ind:int = TreeListData(TreeItemRenderer(tree.itemToItemRenderer(event.item)).listData).rowIndex;
      var
      var
      childItems:Object;
      var
      cursor:IViewCursor;
      //var childItem:Object;
      childItems = descriptor.getChildren(event.item);
      if
      (childItems)
      while
      (!cursor.afterLast)
      //childItem = cursor.current;
      cursor.remove();
      public function getResourceID(event:ListEvent):
      void
      Alert.show(
      "ID:"+ event.currentTarget.selectedItem["id"
      Alert.show(
      "label:"+event.currentTarget.selectedItem["label"
      </mx:Script>
      <mx:Tree x="71" y="45" id="tree" dataProvider="{locationAC}
      " itemOpen="addChildren(event)"
      itemClose="removeItems(event)" dataDescriptor="
      {new MyCustomTreeDataDescriptor()}" itemClick="getResourceID(event)"
      ></mx:Tree>
      </mx:Application>
