1 Reply Latest reply on Aug 22, 2009 8:48 PM by __antonio__
    How do I enable Debugger
    thezenmonkey Level 1
      This may be a total Noob question but I can't seem to get the Flash Debugger to work. I'm trying to test a flash file that interacts with some PHP script.
      I'm running MAMP under OS X 10.5.8
      I've downloaded the Debugger Version of the Flash 10 plug-in and installed it. Created a the mm.cfg in /Library/Application Support/Macromedia with the following content:
      ErrorReportingEnable=1
      TraceOutputFileEnable=1
      Debugging is enabled in the publishing Settings however when I load the file the remote degging session doesn't see the player, and when I control click on it Debugging is disabled.
      Any Help Would be Appreciated
