3 Replies Latest reply on Aug 8, 2012 6:53 AM by robdillon
    How to Edit PSD Files In Flash Template
    sforbis78
      Hi Everyone,
      I am new to flash and I am trying to create my first flash site using a template that I have downloaded. I can edit the first page fine, but when I click the "about us" or any other section, the standard template text, Which isn't even in english, appears. I believe that these are psd files, and I have tried to edit them, saved and replaced file on my computer, but still I get the same unchanged text on this site when I preview. Could someone please tell me how to edit and replace these files within the flash movie?
        • 1. Re: How to Edit PSD Files In Flash Template
          robdillon Most Valuable Participant
          Did your template come with any instructions, information or read me files? In the material in the template folder are there any .txt files or .xml files? Either of these may contain the text that you want to edit. The text may also be static textfields that are part of the Flash movie itself.
          Templates are very difficult to provide help for on a forum. We don't have a copy of the template. Your best source of information is the template content itself and the company that you purchased the template from.
          • 2. Re: How to Edit PSD Files In Flash Template
            Emma4dfuture
            Err.. I designed an interface (Buttons, thumbnails and all), and imported it into Flash Professional; the thing is I don't know how to give instance names to the buttons, thumbnails,' etc. Flash is taking the psd file as a bitmap. Kinda new to Flash Professional, and I need help on what to do here. Would've done it in Flash Catalyst, but CS6 Creative Suite doesn't have Flash catalyst. I want to build an image Gallery.
            • 3. Re: How to Edit PSD Files In Flash Template
              Instance names are the reference names that you give to the individual items on the stage. Only movieClip and button symbols can have instance names.
              When you import a photoshop file to Flash you will get individual bitmap objects on the stage and in a folder in the movie's Library. You will need to select each item, one at a time, on the stage and convert each one to a symbol. When you make that conversion the name that you give to that new movieClip or button is the name that you will see in the Library.
              When you select that new symbol on the stage, look at the Properties window. You will now see a space at the top where you can give that item an instance name. The instance name is what you will use in Actionscript to control that object on the stage.
              When you look in the movie's Library, you will see the original bitmap and the symbol that you created that contains that bitmap.
              Does that help?
