1 Reply Latest reply on Aug 24, 2009 6:36 AM by Kevin Cavallo
    Is there a better way to find the parent?
    JHodnefield
      For speed - I coded the block below - in order to find the index of a parent.
      I need to find a specific subform parent - "part".
      This could be in any number of levels - so I need to spread out my search.
      When the parent is found - tIndex stores the index of that parent.
      There must be a better way to code for this....
      This code looks really horrible:
      if
      (obj.parent.name==
      "part")
      var tIndex =
      obj.parent.index;
      if(obj.parent.parent.name==
      "part")
      var tIndex =
      obj.parent.parent.index;
      if(obj.parent.parent.parent.name==
      "part")
      var tIndex =
      obj.parent.parent.parent.index;
      if(obj.parent.parent.parent.parent.name==
      "part")
      var tIndex =
      obj.parent.parent.parent.parent.index;
      if(obj.parent.parent.parent.parent.parent.name==
      "part")
      var tIndex =
      obj.parent.parent.parent.parent.parent.index;
      if(obj.parent.parent.parent.parent.parent.parent.name==
      "part")
      var tIndex =
      obj.parent.parent.parent.parent.parent.parent.index;
      if(tIndex==null
        • 1. Re: Is there a better way to find the parent?
          Kevin Cavallo Level 4
          How about something like this (untested!).  It should return the index of the most immediate parent that is named part or -1 if none found.
          function findIndex(myObj)
          var ind = -1;
          var obj = myObj.parent;
          while (obj != null)
            if (obj.name == "part")
             ind = obj.index;
             break;
            else
             obj = obj.parent;
          ret ind;
