3 Replies Latest reply on Aug 25, 2009 3:23 AM by Harbs.
    Range.search info
    Dan2205
      Could someone give me info on this method and the parameters it takes? I can't find any info on it anywhere. I'm using CS2 at the moment.
      Cheers
        • 1. Re: Range.search info
          Harbs. Level 6
          What version?
          The search method in the InDesign DOM was used through CS2. In CS3 and
          CS4 it's been replaced by Text.findText() and Text.changeText();
          Unless you are referring to the String.search() method with accepts a
          RegEx...
          Harbs
          • 2. Re: Range.search info
            Dan2205 Level 1
            Thanks for your reply, i'm using CS2 version 4.
            Cheers
            • 3. Re: Range.search info
              Harbs. Level 6
              Here's from the OMV...
              Text.search (for: string , wholeWord: Boolean , caseSensitive:
              Boolean , replacingWith: string , withFindAttributes: Object ,
              withChangeAttributes: Object ):Array of Text
              Adobe InDesign CS4 (4.0) Object Model
              Look for occurrences of text that matches specific criteria
              for: Data Type: string
              What to look for (Optional)
              wholeWord: Data Type: Boolean
              If true, then disregard text embedded within a larger word (Optional)
              caseSensitive: Data Type: Boolean
              If true, then search only for text that matches case (Optional)
              replacingWith: Data Type: string
              What to replace the found text with, either a string or a special
              character (Optional)
              withFindAttributes: Data Type: Object
              A record of find preference settings to use (Optional)
              withChangeAttributes: Data Type: Object
              A record of change preference settings to use (Optional)
              Harbs
