5 Replies Latest reply on Aug 25, 2009 3:57 AM by Niranjan_swain
    How to prevent grid data to be sorted after applying addItemAt() function on dataprovider?
    82.bansal
      I am facing a problem that when I add a new item in datasource of grid using addItemAt() it will also sort the grid data in wiered manner. I need to only add the item to the datasource and not to sort it....... Any help is much appreciated.
      Thanks............
        • 1. Re: How to prevent grid data to be sorted after applying addItemAt() function on dataprovider?
          paul.williams Level 4
          Do you have any sorting already applied to your dataProvider? Has the
          grid been sorted (by clicking a column header) prior to the insert?
          • 2. Re: How to prevent grid data to be sorted after applying addItemAt() function on dataprovider?
            82.bansal Level 1
            Yes grid is sorted before adding items to the datasource............
            • 3. Re: How to prevent grid data to be sorted after applying addItemAt() function on dataprovider?
              Niranjan_swain Level 1
              Hi, do one thing. when u add data to dataprovider of grid at that time u take all ur datagrid column and make there soratable property false.
              example.
              1. suppose ur datagrid name is myGrid.
              2. dataProvider name is myData.
              when u add the data to myData u liked following example
              private var myData:ArrayCollection = new ArrayCollection();
              private function addDataToMyData():void
                   //find all column in ur grid
                   var gridColumns:Array = myGrid.columns;
                   for(var i:int=0; i<gridColumns.length; i++)
                        DataGridColumn(gridColumns[i]).sortable = false;
                   myGrid.columns = gridColumns;
                   var ob:Object = new Object();// set ur data in this object.
                  myData.addItemAt(ob, 3/*index*/);
                    myGrid.dataProvider = myData;
              i think this will help u.
              • 4. Re: How to prevent grid data to be sorted after applying addItemAt() function on dataprovider?
                82.bansal Level 1
                Thanks for the response niranjan, but it doesn't solve my problem. Actually I think grid sorting i8s not the root cause of the problem.
                Let me explain in detail. Suppose I have a 1 column grid wuth data as below:
                2
                2
                2
                3
                3
                3
                4
                4
                No what I do On click of sum button I just sum aa the data in the column and display it aa a new row in the bottom. I am binding my grid with XMLListCollection and to add a new row at botom m using addItemAt() function. I work fine when i make sortablecolumns property of grid = false, but when this property is true then I got this as output
                2
                2
                2
                3
                3
                3
                23  //sum
                4
                4
                However it should give me
                2
                2
                2
                3
                3
                3
                4
                4
                23 // sum
                I hope you understand the problem
                • 5. Re: How to prevent grid data to be sorted after applying addItemAt() function on dataprovider?
                  hai , i am getting ur problem actually  when u sort the column it sort string wise. default sorting of grid column is string.
                  U have to change it to numeric . there is a property compareFunction(). it call when u click on the header for sorting.
                  U apply this column to the datagridColumn which column work with numeric data.in this function body u write ur logic to
                  compare the numeric data. i give a example below
                  private function numeric_CompareFunc(itemA:Object, itemB:Object):int
                              var value1:Number= parseInt(itemA.@fieldName);
                              var  value2:Number = parseInt(itemA.@fieldName);
                              return ObjectUtil.numericCompare(value1, value2);
                  <mx:datagrid  ------>
                  <mx:datagridColumn compareFunction=" numeric_CompareFunc"/>
                  here i am not write the datagrid structure detail. but mentatin how call this function. i sure this will help u.
                  what is the result let me know. if working fine give me some points.
                  Niranjan
