I'm sort of a newbie with some of the context-sensitive Help features.. but can Microsoft HTML Help out be implemented with Context-Senstive Mapping and run from a server where the application is hosted? Or can Microsoft HTML output only be installed and run from the client?
Hi and welcome to the RH community.
You wouldn't want to have a Microsoft HTML Help file located on a server even if it did work. It is designed to run from a local drive and since a MS Security patch won't run on a server or networked drive. If your application runs on a server you'd be better placed to have your output in a form that is designed to be web/server based (i.e. webhelp).
Read the RoboColum(n).
Thanks for the clarification, Colum.
