1 Reply Latest reply on Aug 24, 2009 4:28 PM by Jim_Babbage
    Resolution settings in FW files
    Paevo Kelley Level 2
      I've never changed the default resolution settings from 72 psi; does increasing the resolution dramatically add to file size and or image quality? Do browsers differ on rendering this?
        • 1. Re: Resolution settings in FW files
          Jim_Babbage Level 4
          Browsers render based on pixel dimensions, not ppi. So, assuming that
          you maintain the pixel dimensions and just alter the ppi, nothing will
          happen to the file size.
          If however you alter the resolution and let Fireworks scale the file,
          then yes, the file size will change, and the image quality will also
          change, generally not for the better.
          Jim Babbage
