0 Replies Latest reply on Aug 24, 2009 2:48 PM by GordonSmith
    [svn:fx-trunk] 9546: Integrated build 71 of TLF's mainline (not "1.0") code .
    GordonSmith Level 4
      Revision: 9546
      Author:   gosmith@adobe.com
      Date:     2009-08-24 14:48:20 -0700 (Mon, 24 Aug 2009)
      Log Message:
      Integrated build 71 of TLF's mainline (not "1.0") code.
      QE notes: This is the TLF build from 8/12 that you tested in a cyclone build
      Doc notes: None
      Bugs: None
      Reviewer: None
      Tests run: ant checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/BaseTextLayoutImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/HtmlImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextConverter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextLayoutImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/Build Info.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/BaseCompose.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/StandardFlowComposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/TextFlowLine.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ContainerController.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/debug /Debugging.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/edit/ ISelectionManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/BackgroundManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/Configuration.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowLeafElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/IConfiguration.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/InlineGraphicElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/SubParagraphGroupElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/TCYElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/StringTextLineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/TextFlowTextLineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/facto ry/TextLineFactoryBase.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/ITabStopFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/ITextLayoutFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TabStopFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TabStopFormatInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormatInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormatValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/EditC lasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ SelectionManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ TextClipboard.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ TextFlowEdit.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/ApplyLinkOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/InsertInlineGraphicOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_textField/src/flashx/textLayout/ controls/TLFTextField.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
