2 Replies Latest reply on Aug 25, 2009 4:46 AM by Barna Biro
    Error #1034
    hitesh.rawat
      Hey all,
      I'm trying to run a small piece of code here.........however its giving me an error # 1034. I'm also pasting the instrustions.......plz...check and suggest.
      the MXML part
      <mx:LinkButton x="36" y="447" label="Circle" width="226" id="circle" click="drawCircle()"/>
      the AS part
      public function drawCircle():void
              text1.visible = true;
              text1.text =  "HEllo"//myXML.child(IndexNumber).attribute("source");//.child.length;
              var size:Number = 100;
              var roundObject:Shape = new Shape();
              // red circular shape
              roundObject.graphics.beginFill(0xFF0000);
              roundObject.graphics.moveTo(size / 2, 0);
              roundObject.graphics.curveTo(size, 0, size, size / 2);
              roundObject.graphics.curveTo(size, size, size / 2, size);
              roundObject.graphics.curveTo(0, size, 0, size / 2);
              roundObject.graphics.curveTo(0, 0, size / 2, 0);
              addChild(roundObject);
      Thanks and Regards........
      H.R.
        • 1. Re: Error #1034
          RUSH-ME Level 3
          Hi
          Instead of adding a shape to the container, add the shape to a uicomponent. Then add that uicomponent to the container. Because when you are attempting to add a child to a mx.core.Container
          the child must implement the interface mx.core.IUIComponent and the Shape class does not implements mx.core.IUIComponent. Here is the sample code.
          var myShape:UIcomponent = new UIComponent();
          myShape.addchild(roundObject);
          this.addChild(myshape);
          Hope this helps
          Regards
          Rush-me
          • 2. Re: Error #1034
            Barna Biro Level 3
            Or if you really want to add a Shape, then add it to the rawChildren of the application and not dirrectly to it ( that's why you are getting the error ). But as RUSH-ME said, it would be much better if you work with the Flex API and forget about how you used to do things in Flash.
