0 Replies Latest reply on Aug 25, 2009 8:45 AM by MarsupialsDo
    Date retrieval oddity
    MarsupialsDo
      I have a Flex 3 application retrieving data from ColdFusion.  The function in the cfc runs a simple query and returns the query to the Flex app as an arrayCollection object.  The weirdness comes into play when one or more date fields are returned.  For example, the following query returns just fine:
      SELECT textField1, textField2, numberField1, numberField2 FROM someTable
      The arrayCollection object contains elements corresponding to each field in the query.
      However, the results from the following query are odd:
      SELECT textField1, textField2, numberField1, numberField2, dateField1, dateField2 FROM someTable
      The arrayCollection object contains elements corresponding to each field in the query; however, the value and type of dateField1 is not date, and the value is not the value contained in the database, whiole dateField2 is both the correct type and value .  When I examine the event.Result object in the debugger, the value of the element corresponding to dateField1 appears to be a clone of the entire database record, including the correct value for dateField1 and dateField2.
      Dumping the results of the query in CF gives the expected results for both date fields.
      I have been able to work around the problem by altering the query as follows:
      SELECT textField1, textField2, numberField1, numberField2, dateField1 as BogusDate, dateField1, dateField2 FROM someTable
      To complicate things further, this is happening in some of our development environments but not in others:
      Environment
      DB
      CF  Version
      Flex Builder  Version
      Working?
      Dev 1
      SQL  2008
      CF  8
      3.3.0
      No
      Dev 2
      SQL  2000
      CF  MX7
      3.3.0
      Yes
      Dev 3
      SQL  2005
      CF  8
      3.0.194161
      No
      Dev 4
      SQL2005
      CF  8
      3.3.0
      Yes
      Dev 5SQL 2008CF 83.0.2.214193No
      Needless to say, this is frustrating.  Any help towards a real solution would be welcomed.
      Thanks in advance,
      Leighton
