1 Reply Latest reply on Aug 25, 2009 1:28 PM by matthew horn
    Flex 3 - compile error using mxmlc
    AnnieK Level 1
      Hi All,
      When I compile my flex app using the command line, the following error is thrown:
      [mxmlc] Warning: 'compiler.fonts.flash-type' has been deprecated since 3.0. Please use 'compiler.fonts.advanced-anti-aliasing'.
      [mxmlc]
      [mxmlc] .........Error: Interface IBindingClient was not found.
      Has anyone encountered this before (compiles OK using Flex Builder)?
      Annette
        • 1. Re: Flex 3 - compile error using mxmlc
          matthew horn Level 3
          The name of a compiler option has changed. You can get rid of this error by editing your flex-config.xml file. In there, you might see a line like this:
                  <flash-type>true</flash-type>
          Change it to:
                    <advanced-anti-aliasing>true</advanced-anti-aliasing>
          You don't get it in Flex Builder because it's using a different flex-config.xml file most likely. The difference was made between, I think, versions 3.0 and 3.2 of the SDK.
          hth,
          matt horn
          flex docs
