Revision: 9578
Author: aharui@adobe.com
Date: 2009-08-25 10:23:52 -0700 (Tue, 25 Aug 2009)
Log Message:
Found another embeddedfontcontext issue in the player. ElementFormat.getFontMetrics() must be called in the embeddedFont's moduleFactory context. Added a general "callInContext" API to IFLexModuleFactory. Eventually, TLF will add a new API so they can connect up to this capability and we'll change the code one more time.
QE Notes: None
Doc Notes: New API in IFlexModuleFactory.as
Bugs: SDK-22159
Reviewer: Darrell
API Change: Yes
Is noteworthy for integration: No
tests: checkintests
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-22159
Modified Paths:
flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/WindowedSystemManager.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexModuleFactory.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IFlexModuleFactory.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/SimpleText.as
flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
