4 Replies Latest reply on Aug 25, 2009 2:04 PM by sreeflex
    Read XLIM File in flex
    sreeflex
              Can anybody show me a way to read a xlim or xsl-fo file in flex.  Appreciate your help.
      Thanks in advance
      Sree
        • 1. Re: Read XLIM File in flex
          nagasreekrishna Level 1
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="load()">
          <mx:Script>
                  <![CDATA[
                  public var xmlLoader:URLLoader=new URLLoader();
          function load():void{
                      var xmlString:URLRequest = new URLRequest("items.xml");
                    xmlLoader.load(xmlString);
                  xmlLoader.addEventListener(Event.COMPLETE,init);
             function init(event:Event):void{
                 var xDoc:XMLDocument = new XMLDocument();
              xDoc.ignoreWhite = true;
             var  myXML:XML=XML(xmlLoader.data);
             var fr:String=myXML.items.item[0].Value.toString();
              </mx:Script>
          </mx:Application>
          Suppose this is ur items.xml file
          <items>
            <item>
              <name>jk</name>
              <Value>high</Value>
            </item>
            <item>
              <name>coat</name>
          <Value>medium</Value>
            </item>
             <item>
          <name>milk</name>
          <Value>low</Value>
             </item>
          </items>
          May be u need some imports
          Then the output will be :high(becoz items is  a xml list containing many xml nodes...item[0] is first xml node and Value is the element..toString methods converts it into a string)
          • 2. Re: Read XLIM File in flex
            sreeflex Level 1
            Thanks for the reply. But i want to read data from XLIM  or XSL-FO  file. Not from the XML file. Appreaciate your responce.
            • 3. Re: Read XLIM File in flex
              Barna Biro Level 3
              Same thing. If my memory is not playing tricks on me then XLIM and XLS-FO are also XML structures but with different formatting ( XLS-FO using some namespaces ). Since that's the case, you can always read in any text file ( the format doesn't really matter - what only would matter is the data structure... you'll be easier off with XML-like structures because Flash/Flex can handle that quite well, but if you would be trying to parse plain text... well, that wouldn't be a piece of cake ) and decide to do whatever you want with the content afterward.
              So, just simply try to load the XLS-FO file as you'd load an XML file. You should be able to parse it as any other XML file ( just pay attention to the namespaces when parsing the structure ).
              • 4. Re: Read XLIM File in flex
                sreeflex Level 1
                Thank you very much.I will try this way
