6 Replies Latest reply on Nov 13, 2009 6:46 PM by acath
    Replicating and editing custom components
    kahilburn
      I have created a custom component that I want to reuse multiple times in my designs. I've exported it as a library component and imported into my new project. Once I have added a few instances of this component to my design, I would like to change some of the attributes of a specific instance of this component without changing those attributes for every instance of this component.
      Is there a way to accomplish this?
        • 1. Re: Replicating and editing custom components
          acath Level 4
          Unfortunately, there's no way to expose "knobs", "styles", or "customizations" on your custom components. This is a really interesting topic, and if you have any suggestions for how it would work, I'd love to hear them.
          -Adam
          • 2. Re: Replicating and editing custom components
            kahilburn Level 1
            Adam,
            I totally understand the benefits of having all the instances of a
            particular component linked to a consistent design - for instance, if
            you wanted to apply a different style across the board, it would make
            it mighty easy. However, for those cases in which the user might want
            to modify specific instances of a copied component, here are two
            suggestions for approaches:
            • Unlink whole instances of components - Allow the user to unlink
            specific instances of components from the standard. Once it is
            unlinked, all attributes of the unlinked component could be changeable
            without affecting the other still-linked components. This could be
            handled either during the copy process, or as a separate action after
            the fact.
            • Unlink individual attributes - Allow the user to unlink specific
            attributes of an individual component. This seems technically more
            complex, but would allow the user to create a "template" component and
            then tweak individual instances of that component without having to
            create completely separate copies. Then if the template changed, the
            still-linked attributes would also be updated. Basically, this would
            be like overriding attributes for components.
            I'm sure there are many complexities I haven't yet thought of, but
            hope this helps.
            • 3. Re: Replicating and editing custom components
              acath Level 4
              Ok, thanks. I've added this to our list of possible future features.
              I believe you can work around this by exporting and re-importing the component in the Library panel, thus yielding a duplicate component...
              -Adam
              • 4. Re: Replicating and editing custom components
                kahilburn Level 1
                Thanks Adam. I was aware of this, but hoped there was a way to create "non-linked duplicates" without having to export and re-import for every instance.
                Thanks for clarifying!
                • 5. Re: Replicating and editing custom components
                  avanloov
                  This thread is much more applicable to what I described in http://forums.adobe.com/message/2390554.  Is there any word on the control/configuration of instance-specific property values for custom components?
                  • 6. Re: Replicating and editing custom components
                    acath Level 4
                    Hi Avan,
                    The current version of Catalyst doesn't expose any way to do this. However, we are open to ideas for future versions. Check out the ideas site: http://ideas.adobe.com/labs
                    Of course, there are many ways to make custom components customizable by writing some code in Flash Builder. If you want more guidance on that, let me know.
                    -Adam
